Re: Flawed Warner 145 Exhaust Valve retainers
dcasali
Re: 12V regulator recommendations
Post by dcasali »
'thanks.... I'm going to have to get out to the hanger and take a look. I
don't think I've ever seen more than 15 amps out of the generator, but
that could be a function of the wrong regulator. I'll post again when I
have more info.
ranger440c5 wrote:
> It would be a necessity to know the max output amperage to properly
>size a regulator/controller. The controller has an overcurrent relay
>to kick the gen offline to protect it. I do not know what types of
>gens were certified for use on Warners, but since many, many ,many
>generators have this SAE mount/drive system(4 bolt, 7/8" maj dia
>spline) over the years just about anything could have been mounted up
>and the paperwork ignored.
> Check the gen data plate, likely it's a type397 25 amp unit. If your
>data plate missing don't know where to begin. The type 397 is
>available in several amp capacities and look very much alike physical
>size wise. Since you know it's an Eclipse it must have a data plate,
>right?
> Since it is an Eclipse most of these if not all have isolated fields
>and as such it is possible to set up for type A or B circuit control.
dcasali
Post by dcasali »
'Thanks Tom.
I am going to mail you the failed retainer; it's almost certainly a
"hard" one. I have a parts engine that I will examine next time I can
get to it (it's locked in my mechanic's parts room 70 miles from here)
and see if it is an "E" series. Hopefully it can provide a sample
"soft" retainer to work from.
Does anyone else have a known good retainer? You may find a logbook
entry around 1936 if they were installed....
Melvyn, what's your engine number?
Dan
Tom Downey wrote:
>>Unfortunately, the replacement part bears the same PN as the flawed
>part. Anyone know how one could tell these retainers apart--other
>than finding a hard one in two pieces? And is there a source for
>known good retainers available?
>Uneasily yours,
>Dan Casali
>N2088 1937 24G
>If we had one of each, I can do a rockwell hardeness test on them,
>and duplicate as many as you like.
>Tom Downey
Tom Downey
Post by Tom Downey »
'My Engine is apart, I can check hardness on one of mine.
--- In fairchildclub@yahoogroups.com, Dan Casali
> Thanks Tom.
a
can
here)
logbook
> Dan
dcasali
Post by dcasali »
'I spoke with Harmon Dickerson this morning. He tells me that Warner 165
exhaust valve retainers fit on a Warner 145, and that he has WWII stock
on hand. I've ordered seven.
Jamie -- Harmon's email address is incorrectly listed as
HDAircraft@cf.com in the Parts and Services document: it is actually
HDAircraft@cs.com.
Dan Casali
N2088 1937 24G'
