don't think I've ever seen more than 15 amps out of the generator, but
that could be a function of the wrong regulator. I'll post again when I
have more info.
ranger440c5 wrote:
'> It would be a necessity to know the max output amperage to properly
>size a regulator/controller. The controller has an overcurrent relay
>to kick the gen offline to protect it. I do not know what types of
>gens were certified for use on Warners, but since many, many ,many
>generators have this SAE mount/drive system(4 bolt, 7/8" maj dia
>spline) over the years just about anything could have been mounted up
>and the paperwork ignored.
> Check the gen data plate, likely it's a type397 25 amp unit. If your
>data plate missing don't know where to begin. The type 397 is
>available in several amp capacities and look very much alike physical
>size wise. Since you know it's an Eclipse it must have a data plate,
>right?
> Since it is an Eclipse most of these if not all have isolated fields
>and as such it is possible to set up for type A or B circuit control.
