'Folks,
I have built a new Centre Floor (under the pilots'seats) as per drawing 41484 on the CD ROM as one piece - the drawing is not that clear and I can not see any thing that indicates it is other than one piece.
The old floor was cut into 2 halves and was a piece of cake to put in and take out. The service manual is vague on the matter and only mentions removing screws etc. and infers that it is one bit.
If there is anyone out there who is good at puzzles and has managed to install the centre floor in one piece I would be very happy to hear how it is done. Otherwise I'll cut it in half and make life easy for myself. I don' want to do that if there is a way of doing it.
Many thanks
G-BCBL (HB751)
Re: F24R46 Cockpit floor
'Frank,
My 24R46 and the 24W40 have it in two sections. Split just in front of the
front seats.
Kelly Airpark (http://www.kellyairpark.com)
Elbert, Colorado 80106
303-648-0103
Flying Quote of the Week: If an airplane is still in one piece, don't cheat
on it. Ride the bastard down.
- Ernest K. Gann, Advice from the 'old pelican'
front seats.
303-648-0103
Sent: Saturday, May 01, 2004 10:15 AM
Subject: [fairchildclub] F24R46 Cockpit floor
> Folks,
> Many thanks
> Frank Cox
> G-BCBL (HB751)
'Jamie,
Many thanks - I thought that might be the case - there is just not any other
way to get it to fit.
Frank
Frank
Sent: Saturday, May 01, 2004 5:29 PM
Subject: Re: [fairchildclub] F24R46 Cockpit floor
> Frank,
> front seats.
> 303-648-0103
cheat
> From: "Mr and Mrs F J Cox"
> > Folks,
and
don'
> > Many thanks
> > Frank Cox
> > G-BCBL (HB751)
> > Yahoo! Groups Links
'Frank:
We just made new floorboards for my 1946 F-24R and ran across the
same ambiguity in the drawings as you did. The old floorboard (nasty
and definitely not original) was in two peices so we built the new
one in two peices, as well. Easy to install and remove and no one
will know the difference once it is covered in carpet.
Best Wishes,
Brad Donner
NC77605'
Best Wishes,
Brad Donner
NC77605'
'After the glue dried mine is one piece.
http://www.whidbey.com/fairchildnc19143restoration_com/id18.htm
> Best Wishes,
> Brad Donner
> NC77605
'When I took my Fairchild apart, I did have a one piece floor in the area
under the front seats. I could have put it back in the original condition,
but with the fabric in place, I wouldn't be able to remove it, ever.
I will take a look later this morning, but I am sure that I made the cut
under the pilots seat. I made a splice joint that looked like what was
done on the extreme front three pieced (around the rudder pedals). I used
some Rivnuts on the tabs that comes from the longerons, versus more standard
nuts and bolts. Tinnermans would work well also.
Bob'
Bob'
