'I need to find a nut to fit the end of the prop shaft on my Warner
145. This is the nut at the very end of the taper shaft that holds
the hub in place. Can anyone help with a part no, equivalent or the
actual nut?
Many thanks,
Melvyn Hiscock'
Re: Prop nuts
Re: Prop nuts
'Get a machenist to come measure the threads and size of the nut and mske you
one. Or measure the saft amd tjreads yourself.. john
Sent: Tuesday, January 27, 2004 5:53 AM
Subject: [fairchildclub] Prop nuts
> actual nut?
> Many thanks,
> Melvyn Hiscock
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/fairchildclub/
> Your use of Yahoo! Groups is subject to:
> http://docs.yahoo.com/info/terms/
Re: Prop nuts
'--- In fairchildclub@yahoogroups.com, Melvyn Hiscock
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?
ViewItem&item=2456734449&category=26439'
the> I need to find a nut to fit the end of the prop shaft on my Warner
Is this what you need> actual nut?
> Many thanks,
> Melvyn Hiscock
Re: Prop nuts
'OK the link didn't work, try searching E-Bay motors for item number
2456734449'
2456734449'
Re: Prop nuts
'Melvyn,
According to the Warner engine parts list book.
Part no. 7226, Nut - Prop Hub (Tapered Shaft only)
Two places you might try for a part are,
Harman Dickerson, 573-449-6428
John Duncan, 719-481-4115.
good luck
George'
good luck
George'
Re: Prop nuts
'Melvyn,
I just remembered that a friends widow gave me a small box of 90hp Warner
parts.
I told her I would sell them for her if someone needed them. I looked and
there was a nut for a taper shaft. It is listed in my 1998 parts price list for
$25.30.
(I used to sell parts)
Anyway, It's yours if you want it.
George Olson (859) 277-3303'
parts.
$25.30.
