'I know this isn't Fairchild related but. Does anyone know where I
can find a set of engine cowlings for a 1946 Cessna 120 or 140?
Buell Powell'
Re: Cessna cowlings
Re: Cessna cowlings
'Buell,
Univair has them new, $$$$$.$$. Check with the 120/140 club. One of the
members has them by the gross. If you can not locate, I have a customer that
has his POC.
has his POC.
To: "Fairchildclub"
Sent: Saturday, December 06, 2003 7:45 AM
Subject: [fairchildclub] Cessna cowlings
> Buell Powell
Buell Powell
Re: Cessna cowlings
'Jamie,
Thanks for the information. The owner of the 120 that I am
restoring has tried to locate the cowlings through the 120-140 club without
any luck. We had checked with Univar and they are very expensive and the
could only supply part of them.
I have a couple of Fairchild questions that I would like to
check with you on also. Do you have the information on checking the static
ballance of the ailerons? and the anti-howell srtips for the flap bays?
Thanks very much
Buell Powell
Thanks very much
Buell Powell
Sent: Tuesday, December 09, 2003 6:03 PM
Subject: Re: [fairchildclub] Cessna cowlings
> Buell,
that
> has his POC.
> Jamie S. Treat
> From: "Buell Powell"
> To: "Fairchildclub"
I
> > Buell Powell
