Re: Brakes again
pittss1_s
Brakes again
Post by pittss1_s »
'These brakes are still giving me a heck of a time. One side still
has the old caster oil based fluid and I didn't have any trouble with
it until I moved here to the desert. It now is dragging so I'll only
get one or two landings in it before I get nervous. After it cools
overnight, it's fine. The other side has DOT3 in it and after a lot
of headaches, it was finally turned down to tolerances when I had it
back east (in a humid environment.) It's fine to this day. Any
thoughts?
I'd like to change the castor fluid over to DOT3. What is the best
way?
Wallace Kineyko
NC81284'
Bob and Dot Haas
Re: Brakes again
Post by Bob and Dot Haas »
'Get rid of all that junk fluid flush the system and install
Dot 5 silicone. Be sure all fittings are tight because it will find a
leak, but it washes off with water and will not hurt the finish. It will
not absorb water over a period of time either. No log book entry's
either.
Sent: Sunday, November 09, 2003 12:40 AM
Subject: [fairchildclub] Brakes again
thoughts?
way?
Wallace Kineyko
NC81284
Yahoo! Groups Sponsor
ADVERTISEMENT
click here
Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
Re: Brakes again
Post by Michael Denest »
'Bob's right. Drain and flush, maybe put new seals in
your master cylinders. However, do a maintenance
record entry in your airframe log showing that you
worked on the brakes.
--- Bob and Dot Haas
> system and install
> the finish. It will
> log book entry's
> either.
> From: pittss1_s [mailto:kineyko@hotmail.com]
> One side still
> any trouble with
> After it cools
> and after a lot
> this day. Any
> thoughts?
> What is the best
> way?
> Wallace Kineyko
> NC81284
> ADVERTISEMENT
[/quote]340085:HM/A=1853619/R=0/SIG=11tp41t7d/*http:/www.netflix.com/Default?mqs
> o=60178356&partid=4116719> click here
pmail/S=:HM/A=1853619/rand=766057700>
> Terms of
> Service.
> removed]
[/quote]__________________________________
Do you Yahoo!?
Protect your identity with Yahoo! Mail AddressGuard
http://antispam.yahoo.com/whatsnewfree'
Jamie Treat
Re: Brakes again
Post by Jamie Treat »
'Wallace,
Do what Bob and Mike stated. Flush with De-Natured Alcohol. Run at least a
gallon thru the system. I would replace the master cyl seals. Raybetos Kit
(MK-33). Just use the seals and springs. The rest will not work. As for
logbook entries, I make up a Fluids list. This is so the next person will
not mix fluids which would ruin the system. Also never use Mil-H-5606 in the
brake system. You can switch all you F-24 struts to Dot 5, then you will not
mix match fluids around the airframe.
Sent: Sunday, November 09, 2003 5:29 AM
Subject: RE: [fairchildclub] Brakes again
> Mike
> > system and install
> > the finish. It will
> > log book entry's
> > either.
> > One side still
> > any trouble with
> > After it cools
> > and after a lot
> > this day. Any
> > thoughts?
> > What is the best
> > way?
> > Wallace Kineyko
> > NC81284
> > ADVERTISEMENT
> > Terms of
> > Service.
> > removed]
> Do you Yahoo!?
Tom and Carol Burmeister
Re: Brakes again
Post by Tom and Carol Burmeister »
'The DOT 5 silicone brake fluid is the way to go. FYI, it is also a good idea to change all of the copper gaskets at the banjo fittings located at the inlet of each of the brake expander tubes. The new copper gaskets can be duplicated at most auto parts stores. The copper gaskets are actually on some car airconditioning systems and some auto brake systems. Make sure that every fitting is clean and tight or you will experience leaks.
Bob and Dot Haas wrote: Get rid of all that junk fluid flush the system and install
either.
thoughts?
way?
Wallace Kineyko
NC81284
ADVERTISEMENT
click here
Terms of Service.
Do you Yahoo!?
pittss1_s
Re: Brakes again
Post by pittss1_s »
'Thanks guys,
All of you seem to favor DOT 5. Since the one side has DOT 3 should
I convert it over while I'm at it? Or should I use DOT 3 on both
sides? It seems from what I read that DOT 3 doesn't creep as much
but eats paint and soaks up water. Here in Arizona I don't have to
worry much about the humidity.
Also, do you think that the rubber bladders have swollen out here. I
can't think of a reason why I'd suddenly have a brake drag when I
have never had troubles on that side in the past. Thanks for all of
your help.
Wallace Kineyko
NC81284
--- In fairchildclub@yahoogroups.com, Jamie Treat
> Wallace,
least a
Raybetos Kit
for
person will
5606 in the
will not
> Jamie S. Treat
> From: "Michael Denest"
> > Mike
> > > system and install
> > > the finish. It will
> > > log book entry's
> > > either.
> > > From: pittss1_s [mailto:kineyko@h...]
> > > One side still
> > > any trouble with
> > > After it cools
> > > and after a lot
> > > this day. Any
> > > thoughts?
> > > What is the best
> > > way?
> > > Wallace Kineyko
> > > NC81284
> > > ADVERTISEMENT
mqs
> > > Terms of
> > > Service.
> > > removed]
> > Do you Yahoo!?
Bob & Ileen Waldron
Re: Brakes again
Post by Bob & Ileen Waldron »
'Wallace,
One cause of excessive brake drag, is poor springs located between the pads.
Another cause is partial blockage of the vent hole in the master cylinder.
The vent hole in the cylinder is located under the protective 'tab' that you
can see when you remove the filler plug, and look straight down. I believe
that you can barely get at that hole. If that hole is plugged, then the
pressure won't release, when you take you foot off of the brake.
1939 24 I
rjWaldron@mmmpcc.org
Sent: Sunday, November 09, 2003 7:45 PM
Subject: [fairchildclub] Re: Brakes again
> Thanks guys,
> your help.
> Wallace Kineyko
> NC81284
> wrote:
> > Wallace,
> least a
> Raybetos Kit
> for
> person will
> 5606 in the
> will not
> > Jamie S. Treat
> > To:
> > > Mike
> > > > system and install
> > > > the finish. It will
> > > > log book entry's
> > > > either.
> > > > One side still
> > > > any trouble with
> > > > After it cools
> > > > and after a lot
> > > > this day. Any
> > > > thoughts?
> > > > What is the best
> > > > way?
> > > > Wallace Kineyko
> > > > NC81284
> > > > ADVERTISEMENT
> 05
> mqs
> > > M=267637.4116719.5338353.1261774/D=egrou
> > > > Terms of
> > > > Service.
> > > > removed]
> > > Do you Yahoo!?
pittss1_s
Re: Brakes again
Post by pittss1_s »
'It seems that I kind of overlooked the obvious and didn't check the
vent cap on the master cylinder. The vent ball bearing was stuck and
was pressurizing the system when it was heated. That was why I
could't figure it out that the brake drag went away after the brakes
cooled. Thanks for all of your help with the system anyway. Brakes
are working fine now.
Wallace Kineyko
P.S. Speaking of filler caps does anyone have any spares? Mine are a
little rough and I'd like to replace them.'
