'Thanks to people who responded to my request for info on curing radio
interferance. I took the generator out of the circuit and still had the
noise. I found that with the engine running at low rpm that I could almost
hear each plug firing and the noise increased rapidly when I increased the
rpm. This led me to decide that the noise was caused by the magnetos. I
removed the suppressors or condenser, whichever they are called but I forgot
to try and see if the noise changed with them being removed.
I am now searching for new suppressors but I can't find any part
number on these old ones so I don't how to attach the problem of getting new
ones.
I also have another question: how do people pull an F-24 out of a
hangar with a dirt floor? I use a 12 volt boat winch to pull it back into
the hangar.'
Re: Radio Static
Re: Radio Static
'If you have the landing gear with the tow rings you can drive a dead man out in front of the aircraft the length of the airplane . Then put a pulley with a hook on it attached to the dead man and the cable hooked to your tow bar that is attached to the tow rings. If you don't have the tow rings them just use a tow strap around each gear leg.With the cable going under the aircraft and attached to the dead man and back to the main gear you can pull the the plane out of a dirt floor hanger very easy.
Norbert J Mc Luckie wrote:Thanks to people who responded to my request for info on curing radio
ones.
the hangar.
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
ones.
the hangar.
Do you Yahoo!?
Re: Radio Static
'Norbert,
You might consider putting a pair of ten foot, two by twelves under the main
gear. You could set them into the dirt floor, such that they slope a little
towards the door, that way you would be winching the airplane uphill, and it
would more easily roll out, downhill.
Just a thought.
1939 Fairchild 24K (on a cement floor with an electric tug)
Stillwater, MN
rjWaldron@mmmpcc.org
Just a thought.
Stillwater, MN
Sent: Thursday, July 03, 2003 10:12 PM
Subject: [fairchildclub] Radio Static
almost
forgot
new
> ones.
into
> the hangar.
Re: Radio Static
'My first hangar for my Bellanca had a wooden trough for the tail wheel so it didn't sink into the sandy ground. Nothing more than a 2x6 with 2x2 nailed on each edge as a guide. I made an electric winch to pull it in and then with a dead man with pulley out front, used the winch to pull the tail wheel back down the trough. Worked well. If you are nervous, use a tail wheel steering stick to guide it.
Cy Galley - Bellanca Champion Club
Newsletter Editor & EAA TC
www.bellanca-championclub.com
Actively supporting Aeroncas every day
Quarterly newsletters on time
Reasonable document reprints
1-518-731-6800
1-518-731-6800
Sent: Friday, July 04, 2003 3:12 PM
Subject: Re: [fairchildclub] Radio Static
Norbert,
Just a thought.
Stillwater, MN
almost
forgot
new
> ones.
into
> the hangar.
ADVERTISEMENT
