'I am starting the recovering of my project. I know how it was
stiched before, and I have looked at several others, and they all
seem to be stiched in a different mannor.
Can any one tell me where I can find the proper fuselage and wing
rib stiching pattern?
Mine was stitched at 3" on all stringers from the windscreen to just
behind the cabin, with none on the sides. The wings are at 2" on all
ribs. Is his a correct stiching pattern? I will be required to Show
FSDO and prove where I got the pattern.'
Re: RECOVERING
Re: RECOVERING
The CD has the stitching patterns on the drawings. The fuselage has no stitching and the wing varies. If you do not have the CD I will send you the info.
Gene
Gene
Re: RECOVERING
'Refer to AC43-13-1b. In the fabric covering section,
there is a chart referring to VnE speeds and the
distance between stitches. Unless you know what the
manufacturer did, use the chart. Referencing this
chart on your FAA Form 337 should be ample proof.
--- Tom Downey wrote:
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com'
__________________________________________________> I am starting the recovering of my project. I know
> how it was
> and they all
> fuselage and wing
> windscreen to just
> are at 2" on all
> required to Show
Do you Yahoo!?
Re: RECOVERING
'Haven't received that fork is it still in the shipping stage????Walt
Sent: Monday, September 30, 2002 3:22 AM
Subject: Re: [fairchildclub] RECOVERING
> Tom,
info.
> Gene
Re: RECOVERING
'Walter,
You will get a faster reply if you send it directly to
the person you are inquiring to. Send through the list
will delay your information.
--- WALTER ALBERT wrote:
Do you Yahoo!?
__________________________________________________> Haven't received that fork is it still in the
> From: Gene Lehman
> > Tom,
> The fuselage has no
> info.
> > Gene
> removed]
Do you Yahoo!?
Re: RECOVERING
Tom D.'
has no stitching and the wing varies. If you do not have the CD I> Tom,
I have the CD, what are the drawing numbers?>
> Gene
Tom D.'
Re: RECOVERING
44253 Wing, covered assembly
Gene
Gene
Re: RECOVERING
very poor, as are many prints on the CD.'
I just pulled that drawing up, and can't read it, the blue print is> Tom,
> Gene
