Re: RECOVERING
Tom Downey
RECOVERING
Post by Tom Downey »
'I am starting the recovering of my project. I know how it was
stiched before, and I have looked at several others, and they all
seem to be stiched in a different mannor.
Can any one tell me where I can find the proper fuselage and wing
rib stiching pattern?
Mine was stitched at 3" on all stringers from the windscreen to just
behind the cabin, with none on the sides. The wings are at 2" on all
ribs. Is his a correct stiching pattern? I will be required to Show
FSDO and prove where I got the pattern.'
Gene Lehman
Re: RECOVERING
Post by Gene Lehman »
The CD has the stitching patterns on the drawings. The fuselage has no stitching and the wing varies. If you do not have the CD I will send you the info.
Gene
Re: RECOVERING
Post by Michael Denest »
'Refer to AC43-13-1b. In the fabric covering section,
there is a chart referring to VnE speeds and the
distance between stitches. Unless you know what the
manufacturer did, use the chart. Referencing this
chart on your FAA Form 337 should be ample proof.
> how it was
> and they all
> fuselage and wing
> windscreen to just
> are at 2" on all
> required to Show
Do you Yahoo!?
New DSL Internet Access from SBC & Yahoo!
http://sbc.yahoo.com'
WALTER ALBERT
Re: RECOVERING
Post by WALTER ALBERT »
'Haven't received that fork is it still in the shipping stage????Walt
Sent: Monday, September 30, 2002 3:22 AM
Subject: Re: [fairchildclub] RECOVERING
> Tom,
info.
> Gene
Re: RECOVERING
'Walter,
You will get a faster reply if you send it directly to
the person you are inquiring to. Send through the list
will delay your information.
> From: Gene Lehman
> > Tom,
> The fuselage has no
> info.
> > Gene
> removed]
Do you Yahoo!?
Tom Downey
Re: RECOVERING
'--- In fairchildclub@y..., "Gene Lehman" wrote:
> Tom,
> Gene
I have the CD, what are the drawing numbers?
Tom D.'
Gene Lehman
Re: RECOVERING
44253 Wing, covered assembly
Gene
Tom Downey
Re: RECOVERING
> Tom,
> Gene
I just pulled that drawing up, and can't read it, the blue print is
very poor, as are many prints on the CD.'
