'Does anyone have a part number (such as a NAPA number) for the fuel drain
(Fairchild part number AN771-2) used on each fuel tank on a PT-19/23/26.
Could also be same on an F-24.
Gene Haines
Vintageaircraftgroup.org'
Re: Fuel drains for PT-26
james chybicki
'Sorry Gene
I only have New Old Surplus Fuel Selctor Valves for
the F24.
Only thing I have for PT is a engine mount 1 PT-19 and
1 PT-23, Full instrument panels, Ranger Oil Cooler
(used) and Oil Cooler Inlet Duct.
Not Sure if they are the same, but I have a new set of
Ranger Cowling (olive drab and gray) from a UC-61K
(F24).
--- Pilot4906@aol.com wrote:
Do You Yahoo!?
HotJobs - Search Thousands of New Jobs
http://www.hotjobs.com'
the F24.
(F24).
__________________________________________________> Does anyone have a part number (such as a NAPA
> Gene Haines
Do You Yahoo!?
Bob & Dot Haas
'The quick drain on the 19, 23, 26 are all the same, tapered US pipe thread,
I have got them from A/C Spruce, but I forgot the size, I'll look it up .
Just got back from the Navy Air Museum at Pensacola Fl, Checked out the
Navy version of the PT19, a duramold Timm, 220 Continental, fixed gear,
tandem open cockpit trainer. Bob Haas
Sent: Friday, August 16, 2002 8:11 AM
Subject: [fairchildclub] Fuel drains for PT-26
Gene Haines
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/'
Gene Haines
