Re: PT-19 fuel tank
PT-19 fuel tank
'Is there a fix for a tiny pin-hole leak in a fuel tank? If not, is a replacement tank available anywhere? This a right side tank.
Re: PT-19 fuel tank
'A temp fix is to rub bar soap into the pinhole. Soap is insoluble in
gasoline. A more permanent fix is to clean well and use a glob of JB Weld.
If the tank is tin plate or steel, solder it shut. If it is aluminum, drain,
purge with nitrogen or other non-flammable gas and weld it. DO NOT
pressurize with the gas.
Cy Galley, TC - Chair, Emergency Aircraft Repair, Oshkosh
Editor, EAA Safety Programs
cgalley@qcbc.org or experimenter@eaa.org
Always looking for articles for the Experimenter
Sent: Wednesday, June 19, 2002 8:39 AM
Subject: [fairchildclub] PT-19 fuel tank
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Re: PT-19 fuel tank
'-----Original Message-----
Date: Wednesday, June 19, 2002 8:52 AM
Subject: Re: [fairchildclub] PT-19 fuel tank
Thanks Cy. I'll have it soldered. I'm wondering if there's also a "slosh"
material to use inside the tank while it's removed from the aircraft, just
in case there may be another area that may be thin?
Robert
Robert
drain,>A temp fix is to rub bar soap into the pinhole. Soap is insoluble in
'>purge with nitrogen or other non-flammable gas and weld it. DO NOT
>From: "robert hensarling"
>To:
>Thanks
Re: PT-19 fuel tank
'Robert,
Beware of sloshing compounds, they are not a perm fix. Weld or Solder if you can. Just be careful, do as Cy stated. I have welded many tanks over the years.
Jamie'
Jamie'
Re: PT-19 fuel tank
'I'd stay away from "sloshes" as even Piper has problems with them. They peal
off. They plug up screens, etc. They are bad news.
Cy Galley
Cy Galley
Sent: Thursday, June 20, 2002 10:00 AM
Robert
drain,
>To:
>Thanks
Re: PT-19 fuel tank
Sent: Wednesday, June 19, 2002 11:28 AM
Thanks Cy and Jamie, no sloshes for me!
Robert
> Robert,
years.
> Jamie
Re: PT-19 fuel tank
'Bob,
I have many PT fuel tanks if you cannot fix it I can supply the replacement.
Do you have the type of fuel guages that screw into the tank or the type
that and held in by screws arround the flange?
> Thanks
Re: PT-19 fuel tank
Date: Thursday, June 20, 2002 9:19 AM
That's good to know John, many thanks! My tank has the flange, and the
guage is held in place with a series of screws. Are you tanks NOS? Do you
have an idea of pricing just in case?
Thanks!
Robert
Thanks!
Robert
replacement.>Bob,
'>Do you have the type of fuel guages that screw into the tank or the type
>John Berendt
>To:
>> Thanks
Re: PT-19 fuel tank
'Bob,
They are old stock from the many PT projects I had. Cost proble $50.00 plus
shipping.
shipping.
Sent: Friday, June 21, 2002 2:02 PM
> From: marge&john
you
> Thanks!
> Robert
> >Bob,
> replacement.
> >John Berendt
> >To:
> >> Thanks
Re: PT-19 fuel tank
Date: Friday, June 21, 2002 9:46 AM
Thanks for the info John, will let y ou know what I find out. Trying to get
her all spruced up and sell this summer.
Robert
Robert
plus>Bob,
http://docs.yahoo.com/info/terms/>shipping.
>John Berendt
>To:
>> From: marge&john
>you
>> Thanks!
>> Robert
>> >Bob,
>> replacement.
>> >John Berendt
>> >To:
>> >> Thanks
