PT 26 wing bolts
awilson001@sympatico.ca
PT 26 wing bolts
Hello,New to the forum first post, we are the Canadian Aviation Museum in Windsor Ontario Canada and are the process of reassembling our Fairchild PT26 Cornell. We are in need of one forward wing bolt part # 63136 and one aft wing bolt part # 63137 or the spec’s to manufacture these bolts. Thanks Al
cvairwerks
Re: PT 26 wing bolts
Check with Mike and see if he has the bolt drawings. I know the Air Corps Library does not have them. In the meantime, I'll look thru the AT-21 drawings for the bolts for it. Same design, but different sizes, so the material callouts, threading information and heat treat should be the same.
Craig
AT-21
42-48053
Craig
AT-21
42-48053
Thanks much for the reply Mike. Al
Sorry Craig for the miss name, thanks for the reply how do I connect with Mike. Thanks Al
cvairwerks
Is no sweat, not bothered at all... Mike is Mike Kelly and he runs the club. Here's his online contact info:
Mike Kelly
hotfoot149@gmail.com
Mike Kelly
Thanks Craig. Al
