'I am having new cockpit fuel tank capacity placards made for my PT-26 project. The placard reads "CAPACITY 22 1/2 GALS." and is located behind the LEFT ON/RIGHT ON/BOTH OFF tank selector indicator. These will be made per the original drawing (67617-1) using an acid-etch ink-fill process. They are not made using the flat photo-anodized process you often see. See photos and drawing in the "Cockpit Fuel Tank Capacity Placard" photo folder.
If anyone needs some of these, please let me know. I would like spread the not cheap artwork/setup costs around a bit.Thanks,Pete Crawford
Re: PT Cockpit Fuel Tank Capacity Placard
'Do you have a estimate for the cost? I realize it will depend on the total number madeJohn
Sent from my iPhone
Sent from my iPhone
'You should have another one made -- In Summer Never Fill The Fuel Tanks When Both Seats Are Occupied If A Positive Climb Rate Is Desired.'
