' Does anyone know the distance from the main gear to the tailwheel? Thanks in advance.
Re: Dimensions....
Re: Dimensions....
'I was looking at what you had asked and what that I did is probably better than if I had given you exactly what you asked.The rear most point that I used was the center of the bottom bolt on the vertical fin. I used the square shoulder tire versus the oval. I am sure that would have messed the measurements up. The second point is the very inside, and the very front of the collar on the main strut that the axle fits inside. It is probably a point that won't get damaged. Being as I was alone, it provided a good point to where I could secure one end of the tape measure. The Right side measures 18 feet & 5/16 inch. The Left side was close, 18 feet & 1/2 inch. Considering the right side main attach points were repaired in 1948. Left side was undamaged. The right side attach points spacing and location looks good, but the front fitting was off axis by 0.9 degrees and the rear point was off axis by 1.3 degrees. I had to make 2 sets of custom main gear bushing sets. The Fairchild, when I last flew it handled nicely on hard surfaces and was a delight on grass.I don't know the detail of the accident in 1947, but the right main was damaged, she flipped. The new right wing was pre-war, and the left was UC-61. Motor was changed from Warner to Ranger. Rudder, I have no idea where it came from. It had integral rudder trim. (it had 2 adjustable bows on right side)
'On ?Tuesday?, ?July? ?17?, ?2018? ?03?:?37?:?29? ?PM? ?PDT, Steve Link steven_link@msn.com [fairchildclub] wrote:
Thanks in advance.
#yiv8609020086 #yiv8609020086 -- #yiv8609020086ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv8609020086 #yiv8609020086ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv8609020086 #yiv8609020086ygrp-mkp #yiv8609020086hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv8609020086 #yiv8609020086ygrp-mkp #yiv8609020086ads {margin-bottom:10px;}#yiv8609020086 #yiv8609020086ygrp-mkp .yiv8609020086ad {padding:0 0;}#yiv8609020086 #yiv8609020086ygrp-mkp .yiv8609020086ad p {margin:0;}#yiv8609020086 #yiv8609020086ygrp-mkp .yiv8609020086ad a {color:#0000ff;text-decoration:none;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ygrp-lc {font-family:Arial;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ygrp-lc #yiv8609020086hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ygrp-lc .yiv8609020086ad {margin-bottom:10px;padding:0 0;}#yiv8609020086 #yiv8609020086actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv8609020086 #yiv8609020086activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv8609020086 #yiv8609020086activity span {font-weight:700;}#yiv8609020086 #yiv8609020086activity span:first-child {text-transform:uppercase;}#yiv8609020086 #yiv8609020086activity span a {color:#5085b6;text-decoration:none;}#yiv8609020086 #yiv8609020086activity span span {color:#ff7900;}#yiv8609020086 #yiv8609020086activity span .yiv8609020086underline {text-decoration:underline;}#yiv8609020086 .yiv8609020086attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv8609020086 .yiv8609020086attach div a {text-decoration:none;}#yiv8609020086 .yiv8609020086attach img {border:none;padding-right:5px;}#yiv8609020086 .yiv8609020086attach label {display:block;margin-bottom:5px;}#yiv8609020086 .yiv8609020086attach label a {text-decoration:none;}#yiv8609020086 blockquote {margin:0 0 0 4px;}#yiv8609020086 .yiv8609020086bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv8609020086 .yiv8609020086bold a {text-decoration:none;}#yiv8609020086 dd.yiv8609020086last p a {font-family:Verdana;font-weight:700;}#yiv8609020086 dd.yiv8609020086last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv8609020086 dd.yiv8609020086last p span.yiv8609020086yshortcuts {margin-right:0;}#yiv8609020086 div.yiv8609020086attach-table div div a {text-decoration:none;}#yiv8609020086 div.yiv8609020086attach-table {width:400px;}#yiv8609020086 div.yiv8609020086file-title a, #yiv8609020086 div.yiv8609020086file-title a:active, #yiv8609020086 div.yiv8609020086file-title a:hover, #yiv8609020086 div.yiv8609020086file-title a:visited {text-decoration:none;}#yiv8609020086 div.yiv8609020086photo-title a, #yiv8609020086 div.yiv8609020086photo-title a:active, #yiv8609020086 div.yiv8609020086photo-title a:hover, #yiv8609020086 div.yiv8609020086photo-title a:visited {text-decoration:none;}#yiv8609020086 div#yiv8609020086ygrp-mlmsg #yiv8609020086ygrp-msg p a span.yiv8609020086yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv8609020086 .yiv8609020086green {color:#628c2a;}#yiv8609020086 .yiv8609020086MsoNormal {margin:0 0 0 0;}#yiv8609020086 o {font-size:0;}#yiv8609020086 #yiv8609020086photos div {float:left;width:72px;}#yiv8609020086 #yiv8609020086photos div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}#yiv8609020086 #yiv8609020086photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv8609020086 #yiv8609020086reco-category {font-size:77%;}#yiv8609020086 #yiv8609020086reco-desc {font-size:77%;}#yiv8609020086 .yiv8609020086replbq {margin:4px;}#yiv8609020086 #yiv8609020086ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv8609020086 #yiv8609020086ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv8609020086 #yiv8609020086ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv8609020086 #yiv8609020086ygrp-mlmsg select, #yiv8609020086 input, #yiv8609020086 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv8609020086 #yiv8609020086ygrp-mlmsg pre, #yiv8609020086 code {font:115% monospace;}#yiv8609020086 #yiv8609020086ygrp-mlmsg * {line-height:1.22em;}#yiv8609020086 #yiv8609020086ygrp-mlmsg #yiv8609020086logo {padding-bottom:10px;}#yiv8609020086 #yiv8609020086ygrp-msg p a {font-family:Verdana;}#yiv8609020086 #yiv8609020086ygrp-msg p#yiv8609020086attach-count span {color:#1E66AE;font-weight:700;}#yiv8609020086 #yiv8609020086ygrp-reco #yiv8609020086reco-head {color:#ff7900;font-weight:700;}#yiv8609020086 #yiv8609020086ygrp-reco {margin-bottom:20px;padding:0px;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ov li a {font-size:130%;text-decoration:none;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv8609020086 #yiv8609020086ygrp-sponsor #yiv8609020086ov ul {margin:0;padding:0 0 0 8px;}#yiv8609020086 #yiv8609020086ygrp-text {font-family:Georgia;}#yiv8609020086 #yiv8609020086ygrp-text p {margin:0 0 1em 0;}#yiv8609020086 #yiv8609020086ygrp-text tt {font-size:120%;}#yiv8609020086 #yiv8609020086ygrp-vital ul li:last-child {border-right:none !important;}#yiv8609020086
| | Virus-free. www.avast.com |
Re: Dimensions....
' Sorry, All of that crap at the bottom of the Email that I sent was what happens when you forget that you sometimes can't sent attachments.
#ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899 -- #ygrps-yiv-2072412782yiv5533218899ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp #ygrps-yiv-2072412782yiv5533218899hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp #ygrps-yiv-2072412782yiv5533218899ads { margin-bottom:10px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp .ygrps-yiv-2072412782yiv5533218899ad { padding:0 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp .ygrps-yiv-2072412782yiv5533218899ad p { margin:0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mkp .ygrps-yiv-2072412782yiv5533218899ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ygrp-lc { font-family:Arial;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ygrp-lc #ygrps-yiv-2072412782yiv5533218899hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ygrp-lc .ygrps-yiv-2072412782yiv5533218899ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity span { font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity span span { color:#ff7900;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899activity span .ygrps-yiv-2072412782yiv5533218899underline { text-decoration:underline;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899attach div a { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899attach img { border:none;padding-right:5px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899attach label a { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899bold a { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 dd.ygrps-yiv-2072412782yiv5533218899last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 dd.ygrps-yiv-2072412782yiv5533218899last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 dd.ygrps-yiv-2072412782yiv5533218899last p span.ygrps-yiv-2072412782yiv5533218899yshortcuts { margin-right:0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899attach-table div div a { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899attach-table { width:400px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899file-title a, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899file-title a:active, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899file-title a:hover, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899file-title a:visited { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899photo-title a, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899photo-title a:active, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899photo-title a:hover, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div.ygrps-yiv-2072412782yiv5533218899photo-title a:visited { text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 div#ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg #ygrps-yiv-2072412782yiv5533218899ygrp-msg p a span.ygrps-yiv-2072412782yiv5533218899yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899green { color:#628c2a;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 o { font-size:0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899photos div { float:left;width:72px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899reco-category { font-size:77%;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899reco-desc { font-size:77%;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 .ygrps-yiv-2072412782yiv5533218899replbq { margin:4px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg select, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 input, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg pre, #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 code { font:115% monospace;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-mlmsg #ygrps-yiv-2072412782yiv5533218899logo { padding-bottom:10px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-msg p#ygrps-yiv-2072412782yiv5533218899attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-reco #ygrps-yiv-2072412782yiv5533218899reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-sponsor #ygrps-yiv-2072412782yiv5533218899ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-text { font-family:Georgia;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-text tt { font-size:120%;} #ygrps-yiv-2072412782 #ygrps-yiv-2072412782yiv5533218899 #ygrps-yiv-2072412782yiv5533218899ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2072412782
Virus-free. www.avast.com '
Re: Dimensions....
' #ygrps-yiv-44155570 P {margin-top:0;margin-bottom:0;} LOL!!!! No problem, I forgot to put it was on a PT-23!
From: fairchildclub@yahoogroups.com on behalf of Robert Etter robertetter@ymail.com [fairchildclub]
Sent: Tuesday, July 31, 2018 1:37 PM
To: Steve Link steven_link@msn.com [fairchildclub]
Subject: Re: [fairchildclub] Dimensions.... Sorry, All of that crap at the bottom of the Email that I sent was what happens when you forget that you sometimes can't sent attachments.
Re: Dimensions....
' Fixing that problem with the gear alignment could be a real bear. If it is only a for/aft thing, a good CAD program can get you in the ball park on how much of a shim you would need and where to put it.That problem that I mentioned was a lot of fun. I had to determine what the alignment was on each of the 2 mounting points. Then with the help of a CAD program, I determined what angle difference is between the outer seat and at what angle the center bolt hole should be. Then figure out how to make the pieces. It only took 3 tries to make the first one.Good Luck on your gear.Bob
Virus-free. [url=https://www.avast..com/sig-email?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail&utm_term=link] www.avast.com[/url] #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538 -- #ygrps-yiv-1524786965yiv9057261538ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp #ygrps-yiv-1524786965yiv9057261538hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp #ygrps-yiv-1524786965yiv9057261538ads { margin-bottom:10px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp .ygrps-yiv-1524786965yiv9057261538ad { padding:0 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp .ygrps-yiv-1524786965yiv9057261538ad p { margin:0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mkp .ygrps-yiv-1524786965yiv9057261538ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ygrp-lc { font-family:Arial;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ygrp-lc #ygrps-yiv-1524786965yiv9057261538hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ygrp-lc .ygrps-yiv-1524786965yiv9057261538ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity span { font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity span span { color:#ff7900;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538activity span .ygrps-yiv-1524786965yiv9057261538underline { text-decoration:underline;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538attach div a { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538attach img { border:none;padding-right:5px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538attach label a { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538bold a { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 dd.ygrps-yiv-1524786965yiv9057261538last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 dd.ygrps-yiv-1524786965yiv9057261538last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 dd.ygrps-yiv-1524786965yiv9057261538last p span.ygrps-yiv-1524786965yiv9057261538yshortcuts { margin-right:0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538attach-table div div a { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538attach-table { width:400px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538file-title a, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538file-title a:active, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538file-title a:hover, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538file-title a:visited { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538photo-title a, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538photo-title a:active, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538photo-title a:hover, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div.ygrps-yiv-1524786965yiv9057261538photo-title a:visited { text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 div#ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg #ygrps-yiv-1524786965yiv9057261538ygrp-msg p a span.ygrps-yiv-1524786965yiv9057261538yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538green { color:#628c2a;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 o { font-size:0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538photos div { float:left;width:72px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538reco-category { font-size:77%;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538reco-desc { font-size:77%;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 .ygrps-yiv-1524786965yiv9057261538replbq { margin:4px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg select, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 input, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg pre, #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 code { font:115% monospace;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-mlmsg #ygrps-yiv-1524786965yiv9057261538logo { padding-bottom:10px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-msg p#ygrps-yiv-1524786965yiv9057261538attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-reco #ygrps-yiv-1524786965yiv9057261538reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-sponsor #ygrps-yiv-1524786965yiv9057261538ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-text { font-family:Georgia;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-text tt { font-size:120%;} #ygrps-yiv-1524786965 #ygrps-yiv-1524786965yiv9057261538 #ygrps-yiv-1524786965yiv9057261538ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1524786965 '
On ?Tuesday?, ?July? ?31?, ?2018? ?12?:?34?:?31? ?PM? ?PDT, Steve Link steven_link@msn.com [fairchildclub] wrote:
