'Dear List,
I'm changing some brake lines that are leaking in the middle. The one
connected to the pressure side of the master cylinder has a different
kind of flare nut - with a male thread instead of a female AN818. I've
been looking through my catalogs but can't find one of these. The
Fairchild Parts Manual calls it a "Goodyear' something or other fitting
(don't have the manual in front of me). I can use the old ones but I
like using new fittings when making new brake lines if possible. Are
these available new anywhere? Is this a standard AN fitting or some sort
of special fitting?
David
https://www.avast.com/antivirus'
Re: brake line flare fittings (PT-19)
Ranchaero Wing Shop
Emil Dular
Midland has them, among others. Sometimes called reverse flare fittings. Piper was fond of them through the Sixties.
http://goodyearrubberproducts.com/files/Midland/MidlandCatalog/MidlandCatalog1.Page016.pdf
On 27-Sep-16 23:50, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
Dear List,
of special fitting?
David
