'All,
The detail drawing for the AN5011 hub nut is in the Fairchild Group files. It posted in 2011. Go the group and click on File on top of page.
On Thursday, June 2, 2016 12:07 AM, "Ranchaero Wing Shop
david@ranchaerowingshop.com [fairchildclub]" wrote:
Curt, do you know where could I find the AN5011-20 nut spec?
I measured the cone and spacer which both measure slightly less than 1" (.957 and .995).
Next I need to compare my nut with the spec.
David
On 5/29/2016 7:26 AM, Curt kinchen
ptcurt@gmail.comptcurt@gmail.com [fairchildclub] wrote:
Take it back, it was the nut spec I posted. AN5011.
Sent from my iPad
> I've seen some cones that had "built in" spacers, with a
significant amount of straight section before the taper.
> AN5008-20 cone and AN5010-20 spacer. The non tapered section
Dimension E is shown as .438 in the spec, but I recall seeing some with not that much straight. The link below is for the cone. The spacer spec isn't showing up, but I believe I posted the spec to the files folder at one time.
#ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621 -- #ygrps-yiv-1781441357yiv4702838621ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp #ygrps-yiv-1781441357yiv4702838621hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp #ygrps-yiv-1781441357yiv4702838621ads { margin-bottom:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad { padding:0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad p { margin:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mkp .ygrps-yiv-1781441357yiv4702838621ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc { font-family:Arial;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc #ygrps-yiv-1781441357yiv4702838621hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ygrp-lc .ygrps-yiv-1781441357yiv4702838621ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span { font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span span { color:#ff7900;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621activity span .ygrps-yiv-1781441357yiv4702838621underline { text-decoration:underline;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach div a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach img { border:none;padding-right:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621attach label a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621bold a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 dd.ygrps-yiv-1781441357yiv4702838621last p span.ygrps-yiv-1781441357yiv4702838621yshortcuts { margin-right:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621attach-table div div a { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621attach-table { width:400px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:active, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:hover, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621file-title a:visited { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:active, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:hover, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div.ygrps-yiv-1781441357yiv4702838621photo-title a:visited { text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 div#ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg #ygrps-yiv-1781441357yiv4702838621ygrp-msg p a span.ygrps-yiv-1781441357yiv4702838621yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621green { color:#628c2a;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 o { font-size:0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div { float:left;width:72px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621reco-category { font-size:77%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621reco-desc { font-size:77%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 .ygrps-yiv-1781441357yiv4702838621replbq { margin:4px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg select, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 input, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg pre, #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 code { font:115% monospace;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-mlmsg #ygrps-yiv-1781441357yiv4702838621logo { padding-bottom:10px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-msg p#ygrps-yiv-1781441357yiv4702838621attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-reco #ygrps-yiv-1781441357yiv4702838621reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-sponsor #ygrps-yiv-1781441357yiv4702838621ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text { font-family:Georgia;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-text tt { font-size:120%;} #ygrps-yiv-1781441357 #ygrps-yiv-1781441357yiv4702838621 #ygrps-yiv-1781441357yiv4702838621ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1781441357
