'Dear list,
I'd appreciate if someone could verify for me the fuel pressure and
primer connections to the Stromberg carb. I assume the fitting just
above the fuel inlet is the fuel pressure connection, and the float bowl
drain is where the primer hooks up. Correct?
David
https://www.avast.com/antivirus'
Re: Stromberg carb connections
'Originates at fuel strainer, to primer, to carburetor hot spot..
Pressure connection is correct..
John
From: Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]
Sent: Tuesday, February 2, 2016 8:28 PM
Subject: [fairchildclub] Stromberg carb connections
Dear list,
David
Posted by: Ranchaero Wing Shop
Yahoo Groups Links'
John
Dear list,
David
Yahoo Groups Links'
' John, one other question maybe you can help me with. There is no obvious place on the panel or on the left side of the cockpit to mount the primer. Where was it mounted? There's a PT-26 here at Ranchaero, and it's primer is mounted on a small side panel on the left side of the cockpit. Is this what was done on the -19? If so I'm going to have to find or make such a panel.
Thanks for your help,
David
On 2/3/2016 5:57 AM, 'John Ellis' johnee35@att.net [fairchildclub] wrote:
This email has been sent from a virus-free computer protected by Avast.
www.avast.com '
David
John
Dear list,
David
Posted by: Ranchaero Wing Shop david@ranchaerowingshop.com
Yahoo Groups Links
www.avast.com '
'The primer is located on the engine mount left side next to the spot where the hand crank starter is inserted. The guy who gets to crank the "armstrong" starter injects a couple shots of prime before cranking the engine.
Mike Denest
"He's crazy Lew, he builds toy airplanes!"
- Frank Towns Flight of the Phoenix
On Friday, February 5, 2016 7:56 PM, "Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]" wrote:
David
www.avast.com #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772 -- #ygrps-yiv-1012798498yiv5458772772ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp #ygrps-yiv-1012798498yiv5458772772hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp #ygrps-yiv-1012798498yiv5458772772ads { margin-bottom:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad { padding:0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad p { margin:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mkp .ygrps-yiv-1012798498yiv5458772772ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc { font-family:Arial;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc #ygrps-yiv-1012798498yiv5458772772hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ygrp-lc .ygrps-yiv-1012798498yiv5458772772ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span { font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span span { color:#ff7900;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772activity span .ygrps-yiv-1012798498yiv5458772772underline { text-decoration:underline;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach div a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach img { border:none;padding-right:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772attach label a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772bold a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 dd.ygrps-yiv-1012798498yiv5458772772last p span.ygrps-yiv-1012798498yiv5458772772yshortcuts { margin-right:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772attach-table div div a { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772attach-table { width:400px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:active, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:hover, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772file-title a:visited { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:active, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:hover, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div.ygrps-yiv-1012798498yiv5458772772photo-title a:visited { text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 div#ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg #ygrps-yiv-1012798498yiv5458772772ygrp-msg p a span.ygrps-yiv-1012798498yiv5458772772yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772green { color:#628c2a;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 o { font-size:0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div { float:left;width:72px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772reco-category { font-size:77%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772reco-desc { font-size:77%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 .ygrps-yiv-1012798498yiv5458772772replbq { margin:4px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg select, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 input, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg pre, #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 code { font:115% monospace;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-mlmsg #ygrps-yiv-1012798498yiv5458772772logo { padding-bottom:10px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-msg p#ygrps-yiv-1012798498yiv5458772772attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-reco #ygrps-yiv-1012798498yiv5458772772reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-sponsor #ygrps-yiv-1012798498yiv5458772772ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text { font-family:Georgia;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-text tt { font-size:120%;} #ygrps-yiv-1012798498 #ygrps-yiv-1012798498yiv5458772772 #ygrps-yiv-1012798498yiv5458772772ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1012798498
Mike Denest
David
John
Dear list,
David
Yahoo Groups Links
' Ah! that explains it. So I'll need to make my own mount in the cockpit.
Thanks for the help, Mike!
David
www.avast.com
www.avast.com '
David
Mike Denest
On Friday, February 5, 2016 7:56 PM, "Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]" fairchildclub@yahoogroups.com wrote:
David
John
Dear list,
David
Yahoo Groups Links
www.avast.com
www.avast.com '
'Hi Michael I hear that you are the guy when it comes to RANGER engines, & I was just wondering if you could let me know what do you think is the best oil to use for that engine? I just purchased apt 26 from Nick Kelly and amarillo I love the airplane but the only 1 I'm familiar with have the Continental ENGINE my dad had a PT 23 I'm at was 45 years ago anyway thank you for any information you feel you can send preciate it tonyanger@cox.net
Sent from my Sprint Samsung Galaxy S® 6.-------- Original message --------From: "Michael Denest mjd12k@yahoo.com [fairchildclub]" Date: 2/5/2016 1:21 PM (GMT-07:00) To: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] Stromberg carb connections
Mike Denest
David
www.avast.com
Mike Denest
David
John
Dear list,
David
Yahoo Groups Links
www.avast.com
