I have "C" channel for Warner Motor Mounts
Post by robert Etter »
'I have plenty of "C" channel rubber for the motor mounts for Warners 165's if you need some.  The attachment is spells out what I bought &  from where.  I believe 5 pieces of 7.5 inch in length is enough (37.5" overall).   I will cut 45", to give you extra to play with.  At least that is what I call messing up.  Cutting it square using a blade isn't easy.  The dimension is 3/4" X 3/4" and the cut out measures 1/2" X 1/2".  Measures the same as what I took off.  It is soft, versus hard as a brick.  The price comes out to be about $3.00 per foot plus postage, and a soft pack envelope or a short tube.  Short pieces, your choice of length, or 1 long length.Bob775-482-9243
