Re: PT tires
Steve Link
PT tires
'How do you guys have your PT tires installed since they are not split rims…..'
Pattee News
Re: PT tires
'I just did the tires last month.I found a tire shop that had experienced guys. The big brand tire stores didn't give me the best feeling. Most tire machines have the spades required to dig under the bead of the tire and grip the rim. No marks/scratches left.
On Jul 12, 2015, at 14:26, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
Re: PT tires
'I can basically tell you how I did it, but it has been a long time ago so the details are lost in my mind.As I am sure, you have tried it. Fighting a tire and wheel is a bear. The first thing that I did was to bolt the wheel down to a heavy work bench. Secondly is the part that I vaguely remember. I used a cheap spring compressor to pull the tire across the wheel. I think that I may have used a shop towels to cushion the jaw of the spring compressor as to not mark the wheel, then hooked one jaw to the wheel and the opposite jaw to the tire. Then tightened the bolt. As you can imagine, the only time that things get tight is when the tire is half way across the wheel. Once you get more the half way point, everything get easier. I think that I may have used a dead blow hammer somewhere in the process, so I wouldn't hit and mark the wheel. I don't think the hammer was than a release of tension, early on. The spring compressor was just 18" X 5/8" threaded rod, nuts at both ends, and 2 sliding hooks. I started out using many 4 letter words. Then bolted the wheel down, and tried the spring compressor. End result, I didn't hurt the wheel, tire tube, and didn't even work up a good sweat. Really the hardest part was finding a big bolt and a matching washer, in my junk, that fit inside the wheel.It is the only time that I used the tool. I bought it 30 years ago when working on the front end of a MG. Found that it wasn't required.You can take everything with a gran of salt, but it worked.Good LuckBob
On Tuesday, July 14, 2015 1:30 AM, "Pattee News patteenews@gmail.com [fairchildclub]" wrote:
#ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859 -- #ygrps-yiv-1514938448yiv5428109859ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp #ygrps-yiv-1514938448yiv5428109859hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp #ygrps-yiv-1514938448yiv5428109859ads { margin-bottom:10px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp .ygrps-yiv-1514938448yiv5428109859ad { padding:0 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp .ygrps-yiv-1514938448yiv5428109859ad p { margin:0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mkp .ygrps-yiv-1514938448yiv5428109859ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ygrp-lc { font-family:Arial;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ygrp-lc #ygrps-yiv-1514938448yiv5428109859hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ygrp-lc .ygrps-yiv-1514938448yiv5428109859ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity span { font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity span span { color:#ff7900;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859activity span .ygrps-yiv-1514938448yiv5428109859underline { text-decoration:underline;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859attach div a { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859attach img { border:none;padding-right:5px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859attach label a { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859bold a { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 dd.ygrps-yiv-1514938448yiv5428109859last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 dd.ygrps-yiv-1514938448yiv5428109859last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 dd.ygrps-yiv-1514938448yiv5428109859last p span.ygrps-yiv-1514938448yiv5428109859yshortcuts { margin-right:0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859attach-table div div a { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859attach-table { width:400px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859file-title a, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859file-title a:active, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859file-title a:hover, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859file-title a:visited { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859photo-title a, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859photo-title a:active, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859photo-title a:hover, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div.ygrps-yiv-1514938448yiv5428109859photo-title a:visited { text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 div#ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg #ygrps-yiv-1514938448yiv5428109859ygrp-msg p a span.ygrps-yiv-1514938448yiv5428109859yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859green { color:#628c2a;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 o { font-size:0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859photos div { float:left;width:72px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859reco-category { font-size:77%;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859reco-desc { font-size:77%;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 .ygrps-yiv-1514938448yiv5428109859replbq { margin:4px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg select, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 input, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg pre, #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 code { font:115% monospace;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-mlmsg #ygrps-yiv-1514938448yiv5428109859logo { padding-bottom:10px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-msg p#ygrps-yiv-1514938448yiv5428109859attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-reco #ygrps-yiv-1514938448yiv5428109859reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-sponsor #ygrps-yiv-1514938448yiv5428109859ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-text { font-family:Georgia;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-text tt { font-size:120%;} #ygrps-yiv-1514938448 #ygrps-yiv-1514938448yiv5428109859 #ygrps-yiv-1514938448yiv5428109859ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1514938448How do you guys have your PT tires installed since they are not split rims…..
Steve Link
Re: PT tires
' LOL!!!!!!!!!!!!!!!!!! Thanks Bob!
Date: Thu, 16 Jul 2015 16:10:34 +0000
Subject: Re: [fairchildclub] PT tires
Re: PT tires
'I agree.If I had another tire of any condition, I would take pictures for you.I do a pretty good job. I build both wings from scratch, all new wood and minor hardware, and missed the perfect rigging by 3/4" total. That is from center aileron mount to rudder post.After 40 plus years of working, not full time, I may actually fly again within the next year. Once the wheels clear the runway, I will have the worst case of shakes you have ever seen. Thankfully, it will only last a minute or two. That is what happened to me with my Cub. At least with the Cub, the front seat was in the way, so my knees weren't banging together. By the time I got to the end of the runway, it was all better.Tasks remaining. Put color on left wing and hang it. Put fabric and color on right wing and hang it. and hang a Warner.Bob
'On Thursday, July 16, 2015 9:19 AM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
#yiv6126038658 #yiv6126038658 -- #yiv6126038658ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv6126038658 #yiv6126038658ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv6126038658 #yiv6126038658ygrp-mkp #yiv6126038658hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv6126038658 #yiv6126038658ygrp-mkp #yiv6126038658ads {margin-bottom:10px;}#yiv6126038658 #yiv6126038658ygrp-mkp .yiv6126038658ad {padding:0 0;}#yiv6126038658 #yiv6126038658ygrp-mkp .yiv6126038658ad p {margin:0;}#yiv6126038658 #yiv6126038658ygrp-mkp .yiv6126038658ad a {color:#0000ff;text-decoration:none;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ygrp-lc {font-family:Arial;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ygrp-lc #yiv6126038658hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ygrp-lc .yiv6126038658ad {margin-bottom:10px;padding:0 0;}#yiv6126038658 #yiv6126038658actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv6126038658 #yiv6126038658activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv6126038658 #yiv6126038658activity span {font-weight:700;}#yiv6126038658 #yiv6126038658activity span:first-child {text-transform:uppercase;}#yiv6126038658 #yiv6126038658activity span a {color:#5085b6;text-decoration:none;}#yiv6126038658 #yiv6126038658activity span span {color:#ff7900;}#yiv6126038658 #yiv6126038658activity span .yiv6126038658underline {text-decoration:underline;}#yiv6126038658 .yiv6126038658attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv6126038658 .yiv6126038658attach div a {text-decoration:none;}#yiv6126038658 .yiv6126038658attach img {border:none;padding-right:5px;}#yiv6126038658 .yiv6126038658attach label {display:block;margin-bottom:5px;}#yiv6126038658 .yiv6126038658attach label a {text-decoration:none;}#yiv6126038658 blockquote {margin:0 0 0 4px;}#yiv6126038658 .yiv6126038658bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv6126038658 .yiv6126038658bold a {text-decoration:none;}#yiv6126038658 dd.yiv6126038658last p a {font-family:Verdana;font-weight:700;}#yiv6126038658 dd.yiv6126038658last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv6126038658 dd.yiv6126038658last p span.yiv6126038658yshortcuts {margin-right:0;}#yiv6126038658 div.yiv6126038658attach-table div div a {text-decoration:none;}#yiv6126038658 div.yiv6126038658attach-table {width:400px;}#yiv6126038658 div.yiv6126038658file-title a, #yiv6126038658 div.yiv6126038658file-title a:active, #yiv6126038658 div.yiv6126038658file-title a:hover, #yiv6126038658 div.yiv6126038658file-title a:visited {text-decoration:none;}#yiv6126038658 div.yiv6126038658photo-title a, #yiv6126038658 div.yiv6126038658photo-title a:active, #yiv6126038658 div.yiv6126038658photo-title a:hover, #yiv6126038658 div.yiv6126038658photo-title a:visited {text-decoration:none;}#yiv6126038658 div#yiv6126038658ygrp-mlmsg #yiv6126038658ygrp-msg p a span.yiv6126038658yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv6126038658 .yiv6126038658green {color:#628c2a;}#yiv6126038658 .yiv6126038658MsoNormal {margin:0 0 0 0;}#yiv6126038658 o {font-size:0;}#yiv6126038658 #yiv6126038658photos div {float:left;width:72px;}#yiv6126038658 #yiv6126038658photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv6126038658 #yiv6126038658photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv6126038658 #yiv6126038658reco-category {font-size:77%;}#yiv6126038658 #yiv6126038658reco-desc {font-size:77%;}#yiv6126038658 .yiv6126038658replbq {margin:4px;}#yiv6126038658 #yiv6126038658ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv6126038658 #yiv6126038658ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv6126038658 #yiv6126038658ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv6126038658 #yiv6126038658ygrp-mlmsg select, #yiv6126038658 input, #yiv6126038658 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv6126038658 #yiv6126038658ygrp-mlmsg pre, #yiv6126038658 code {font:115% monospace;}#yiv6126038658 #yiv6126038658ygrp-mlmsg * {line-height:1.22em;}#yiv6126038658 #yiv6126038658ygrp-mlmsg #yiv6126038658logo {padding-bottom:10px;}#yiv6126038658 #yiv6126038658ygrp-msg p a {font-family:Verdana;}#yiv6126038658 #yiv6126038658ygrp-msg p#yiv6126038658attach-count span {color:#1E66AE;font-weight:700;}#yiv6126038658 #yiv6126038658ygrp-reco #yiv6126038658reco-head {color:#ff7900;font-weight:700;}#yiv6126038658 #yiv6126038658ygrp-reco {margin-bottom:20px;padding:0px;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ov li a {font-size:130%;text-decoration:none;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv6126038658 #yiv6126038658ygrp-sponsor #yiv6126038658ov ul {margin:0;padding:0 0 0 8px;}#yiv6126038658 #yiv6126038658ygrp-text {font-family:Georgia;}#yiv6126038658 #yiv6126038658ygrp-text p {margin:0 0 1em 0;}#yiv6126038658 #yiv6126038658ygrp-text tt {font-size:120%;}#yiv6126038658 #yiv6126038658ygrp-vital ul li:last-child {border-right:none !important;}#yiv6126038658
