Warner Motor mount outer shell diameter.
'Am I correct? Is the outside diameter of the outer bushing shell for the rubber mounts 1.247"? (Ref: dwg. #48568) If that is true, darn.....they, the outer shells, are sure tough to get out. If the outer diameter is more like 1.100", then I am trying to remove the wrong pieces, and my outer shells have already been removed and I am SOL. Short On Luck. I am making progress. I have the tail group & ailerons up through the early coats of silver. I may have them all up through color and have made final assembly within 2-3 months. Bob'
