'Hi AllJust a quick question for Ranger Operators.What is the drawback from using single stack exhaust pipes on the 200 HP Ranger?If they are used, how long should/ can they be?
Jim CMidwest AeronautiqueUC-61K USAAF# 43-14964 RAF # HB-690
still looking for:UC-61/ PT-19 Pitot TubeUC-61K / F24R with Throttle/Mixture pushrod Engine Mount.
Re: Single Stacks on Ranger
Airy-H. Millet
' Only one advantage...it is easier than 3-in-1 to weld and to screw on engine!
But it is not really better for the engine as they are too short to keep the counter pressure from the atmosphere.
Most of the time front stack is shorter than firewall-side stack...
http://tagazous.free.fr/affichage2.php?img=4158
Moreover, you may experience loosing one during flight... (six more items to check at pre-flight, hitting each stack with your screwdriver* to ear the clear sound of a well tight stack or feel one looseness.....)
*the one you need to open/close oil door, battery door, etc...
Airy
Date: Wed, 28 May 2014 06:36:27 -0700
Subject: [fairchildclub] Single Stacks on Ranger
Hi All Just a quick question for Ranger Operators. What is the drawback from using single stack exhaust pipes on the 200 HP Ranger? If they are used, how long should/ can they be?
Jim C Midwest Aeronautique UC-61K USAAF# 43-14964 RAF # HB-690
still looking for: UC-61/ PT-19 Pitot Tube UC-61K / F24R with Throttle/Mixture pushrod Engine Mount.
Airy
Fritz Mehrer
'I have a set of “singles” that I intend putting on my PT 200. I will pull them out and measure length now since I didn’t know they are shorter in the front. I’ll let you know the lengths. Fritz From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, May 28, 2014 6:48 AM
To: fairchildlist
Subject: RE: [fairchildclub] Single Stacks on Ranger
Airy
Hi AllJust a quick question for Ranger Operators.What is the drawback from using single stack exhaust pipes on the 200 HP Ranger?If they are used, how long should/ can they be? Jim CMidwest AeronautiqueUC-61K USAAF# 43-14964 RAF # HB-690 still looking for:UC-61/ PT-19 Pitot TubeUC-61K / F24R with Throttle/Mixture pushrod Engine Mount.
To: fairchildlist
Airy
james chybicki
'Hi Airy!It's been a while since we have spoken. Do you still own you UC-61K?The picture you linked of your plane shows the stacks all look to be the same length. I have a set of Stainless Steel pipes and the are all different lengths. the shortest at 6 inches (15.24 cm) up to 1 foot long (30.48 cm).
How does one measure the counter pressure?
Take CareCheers!JIM
On Wednesday, May 28, 2014 10:35 AM, "'Airy-H. Millet' flyingairy@hotmail.com [fairchildclub]" wrote:
Airy
#ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441 -- #ygrps-yiv-1487019790yiv6542284441ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp #ygrps-yiv-1487019790yiv6542284441hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp #ygrps-yiv-1487019790yiv6542284441ads { margin-bottom:10px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp .ygrps-yiv-1487019790yiv6542284441ad { padding:0 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp .ygrps-yiv-1487019790yiv6542284441ad p { margin:0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mkp .ygrps-yiv-1487019790yiv6542284441ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ygrp-lc { font-family:Arial;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ygrp-lc #ygrps-yiv-1487019790yiv6542284441hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ygrp-lc .ygrps-yiv-1487019790yiv6542284441ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity span { font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity span span { color:#ff7900;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441activity span .ygrps-yiv-1487019790yiv6542284441underline { text-decoration:underline;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441attach div a { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441attach img { border:none;padding-right:5px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441attach label a { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441bold a { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 dd.ygrps-yiv-1487019790yiv6542284441last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 dd.ygrps-yiv-1487019790yiv6542284441last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 dd.ygrps-yiv-1487019790yiv6542284441last p span.ygrps-yiv-1487019790yiv6542284441yshortcuts { margin-right:0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441attach-table div div a { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441attach-table { width:400px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441file-title a, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441file-title a:active, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441file-title a:hover, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441file-title a:visited { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441photo-title a, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441photo-title a:active, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441photo-title a:hover, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div.ygrps-yiv-1487019790yiv6542284441photo-title a:visited { text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 div#ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg #ygrps-yiv-1487019790yiv6542284441ygrp-msg p a span.ygrps-yiv-1487019790yiv6542284441yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441green { color:#628c2a;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 o { font-size:0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441photos div { float:left;width:72px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441reco-category { font-size:77%;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441reco-desc { font-size:77%;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 .ygrps-yiv-1487019790yiv6542284441replbq { margin:4px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg select, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 input, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg pre, #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 code { font:115% monospace;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-mlmsg #ygrps-yiv-1487019790yiv6542284441logo { padding-bottom:10px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-msg p#ygrps-yiv-1487019790yiv6542284441attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-reco #ygrps-yiv-1487019790yiv6542284441reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-sponsor #ygrps-yiv-1487019790yiv6542284441ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-text { font-family:Georgia;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-text tt { font-size:120%;} #ygrps-yiv-1487019790 #ygrps-yiv-1487019790yiv6542284441 #ygrps-yiv-1487019790yiv6542284441ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1487019790
Take CareCheers!JIM
Airy
Airy-H. Millet
' Hi Jim!
Not writing a lot at all but still reading often!
So, our UC-61K is now in the hands of Jean-Pierre Gandon, 40minutes flight South from our base, and he reads now this forum too!
Apparently all stacks "looks like" beeing the same length, but if you look carefully at the cowlings shape knowing that Inside them the engine is horizontally straight you'll obviously notice that all stacks couldn't really bee identical.
To the front cowlings are narrowing the nose, to the firewall sides they are enlarging sideways AND horizontally (a bit more at the bottom than on the top).
The counter pressure phenomenom is not that easy to explain:
-In one side you have the atmosphere...1013.25 hPa (mbar), or 1 atm on older units. (sorry I'm not familiar with inch Hg). ("low" temperature and quite "high" viscosity"...
-On the other side, you have the flow+pressure front starting from the exhaust valve seat at each valve opening with very hot, high pressure, and fast gas velocity (warm gas are more fluid than cold intake gas, the viscosity of exhaust gas is very low).
Then you have the 4-cycle "otto cycle" of the engine, and you now the cruise and/or full rpm you want to optimize.
Thus you got the "frequency" of exhaust shock waves.
With some empiric knowledges and some other measurements on test bench, specialists could then determine the optimum length of a pipe depending of EGT and gas velocity along the pipe to get all the gas in the "cold" atmosphere at the best rate.
Then, basic principle shows that all the pipes should have the same length, even when merging some of them together, or merging them at precise length being multiple of a basic length to enhance gas flow.
More over, longer are the pipes, more the gas temperature diminish along the travel...and figures of calculations changed. Density/viscosity evolve along the pipe (that why some race cars use thermal screens and wraps to keep the pipes as warm as possible to keep the exhaust heat Inside the pipe).
So, I do not know precisely the optimum values for Ranger engines, and it is noticeable that on low rpm running engines the "power" gain is low, and that merely only the thermal homogeneity is to be considered first, getting the heat outside with the best conditions to keep the valves and their seats at the same temp' on each cylinders. (let say keeping all heads at the same temperature too).
Beside those "engineering" considérations, the exhausts sound could be changed quite a lot (even quieter) playing with pipes length!
Have a nice day!
And fly safe!
cheers,
Airy
Date: Wed, 28 May 2014 10:37:42 -0700
Subject: Re: [fairchildclub] Single Stacks on Ranger
Take CareCheers!JIM
Airy
Have a nice day!
And fly safe!
cheers,
Airy
Take CareCheers!JIM
Airy
Fritz Mehrer
'Ok, the following are the overall lengths of my 6 exhaust pipes
including the 45 degree portion. I have attached a photo just for
fun.
14, 12 ½, 11, 10, 9, and 8 inches.
Fritz
To: fairchildlist
engine!
looseness.....)
Airy
_____
Hi All
HP Ranger?
Jim C
still looking for:
fun.
Fritz
To: fairchildlist
engine!
looseness.....)
Airy
_____
Hi All
HP Ranger?
Jim C
still looking for:
Hugh Loewenhardt
'Jim, Airy is talking about a "tuned exhaust system". Google 'tuned exhaust system' for full, in-depth, educational discussions on the subject.
On Wednesday, May 28, 2014 9:36 AM, "james chybicki rampratone@yahoo.com [fairchildclub]" wrote:
#ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656 -- #ygrps-yiv-1228161726yiv9739193656ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp #ygrps-yiv-1228161726yiv9739193656hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp #ygrps-yiv-1228161726yiv9739193656ads { margin-bottom:10px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp .ygrps-yiv-1228161726yiv9739193656ad { padding:0 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp .ygrps-yiv-1228161726yiv9739193656ad p { margin:0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mkp .ygrps-yiv-1228161726yiv9739193656ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ygrp-lc { font-family:Arial;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ygrp-lc #ygrps-yiv-1228161726yiv9739193656hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ygrp-lc .ygrps-yiv-1228161726yiv9739193656ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity span { font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity span span { color:#ff7900;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656activity span .ygrps-yiv-1228161726yiv9739193656underline { text-decoration:underline;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656attach div a { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656attach img { border:none;padding-right:5px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656attach label a { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656bold a { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 dd.ygrps-yiv-1228161726yiv9739193656last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 dd.ygrps-yiv-1228161726yiv9739193656last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 dd.ygrps-yiv-1228161726yiv9739193656last p span.ygrps-yiv-1228161726yiv9739193656yshortcuts { margin-right:0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656attach-table div div a { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656attach-table { width:400px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656file-title a, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656file-title a:active, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656file-title a:hover, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656file-title a:visited { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656photo-title a, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656photo-title a:active, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656photo-title a:hover, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div.ygrps-yiv-1228161726yiv9739193656photo-title a:visited { text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 div#ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg #ygrps-yiv-1228161726yiv9739193656ygrp-msg p a span.ygrps-yiv-1228161726yiv9739193656yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656green { color:#628c2a;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 o { font-size:0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656photos div { float:left;width:72px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656reco-category { font-size:77%;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656reco-desc { font-size:77%;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 .ygrps-yiv-1228161726yiv9739193656replbq { margin:4px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg select, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 input, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg pre, #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 code { font:115% monospace;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-mlmsg #ygrps-yiv-1228161726yiv9739193656logo { padding-bottom:10px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-msg p#ygrps-yiv-1228161726yiv9739193656attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-reco #ygrps-yiv-1228161726yiv9739193656reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-sponsor #ygrps-yiv-1228161726yiv9739193656ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-text { font-family:Georgia;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-text tt { font-size:120%;} #ygrps-yiv-1228161726 #ygrps-yiv-1228161726yiv9739193656 #ygrps-yiv-1228161726yiv9739193656ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1228161726
