Interesting Fairchild project for sale
gilmoreredlion
Cleaning Warner cylinders
'Hi group,What's the best way to clean carbon from the cylinder head, exhaust and intake ports? How about the paint from the outside of the cylinder?Thanks, Mark Gilmore(Working on Brett Gilmore's 81288 Warner)'
Re: Cleaning Warner cylinders
'Glass beads or walnut media. JST From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of gilmoreredlion@yahoo.com
Sent: Sunday, February 23, 2014 3:15 PM
Subject: [fairchildclub] Cleaning Warner cylinders
Mark Gilmore
'Thanks Jamie
Sent from my iPad
Sent from my iPad
Jan Servaites
' Dip them in a gallon or so of carb cleaner. It will take it all off, including paint
Jan
gilmoreredlion@yahoo.com wrote:
Jan
Hi group, What's the best way to clean carbon from the cylinder head, exhaust and intake ports? How about the paint from the outside of the cylinder? Thanks, Mark Gilmore (Working on Brett Gilmore's 81288 Warner)
Pete Crawford
' Mark,
Hydro-Sol works well on carbon.
Pete Crawford
Pete Crawford
'The best and easiest way is to send the cylinder in for service. If your cylinder needs chroming they have to bead blast it anyway, no matter how clean it is when they receive it. If for whatever reason you want to clean it your self, bead blasting with medium grit (80) works well but, you need a pretty good air compressor and blast cabinet. The large Harbor Freight cabinet works well if the exhaust vent is connected to a shop vac. They also sell the glass bead. As Jan said, earlier, the paint comes off easy with the carb cleaner. I personally have not had success with the carbon. maybe I am using the wrong brand. Caution, if you send it out to be cleaned anywhere other than an FAA certified shop, be absolutely sure that they will use glass bead and not sand.JP.
#ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547 -- #ygrps-yiv-1788563622yiv4329483547ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp #ygrps-yiv-1788563622yiv4329483547hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp #ygrps-yiv-1788563622yiv4329483547ads { margin-bottom:10px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp .ygrps-yiv-1788563622yiv4329483547ad { padding:0 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp .ygrps-yiv-1788563622yiv4329483547ad p { margin:0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mkp .ygrps-yiv-1788563622yiv4329483547ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ygrp-lc { font-family:Arial;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ygrp-lc #ygrps-yiv-1788563622yiv4329483547hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ygrp-lc .ygrps-yiv-1788563622yiv4329483547ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity span { font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity span span { color:#ff7900;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547activity span .ygrps-yiv-1788563622yiv4329483547underline { text-decoration:underline;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547attach div a { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547attach img { border:none;padding-right:5px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547attach label a { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547bold a { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 dd.ygrps-yiv-1788563622yiv4329483547last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 dd.ygrps-yiv-1788563622yiv4329483547last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 dd.ygrps-yiv-1788563622yiv4329483547last p span.ygrps-yiv-1788563622yiv4329483547yshortcuts { margin-right:0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547attach-table div div a { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547attach-table { width:400px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547file-title a, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547file-title a:active, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547file-title a:hover, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547file-title a:visited { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547photo-title a, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547photo-title a:active, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547photo-title a:hover, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div.ygrps-yiv-1788563622yiv4329483547photo-title a:visited { text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 div#ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg #ygrps-yiv-1788563622yiv4329483547ygrp-msg p a span.ygrps-yiv-1788563622yiv4329483547yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547green { color:#628c2a;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 o { font-size:0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547photos div { float:left;width:72px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547reco-category { font-size:77%;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547reco-desc { font-size:77%;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 .ygrps-yiv-1788563622yiv4329483547replbq { margin:4px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg select, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 input, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg pre, #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 code { font:115% monospace;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-mlmsg #ygrps-yiv-1788563622yiv4329483547logo { padding-bottom:10px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-msg p#ygrps-yiv-1788563622yiv4329483547attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-reco #ygrps-yiv-1788563622yiv4329483547reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-sponsor #ygrps-yiv-1788563622yiv4329483547ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-text { font-family:Georgia;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-text tt { font-size:120%;} #ygrps-yiv-1788563622 #ygrps-yiv-1788563622yiv4329483547 #ygrps-yiv-1788563622yiv4329483547ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1788563622Dip them in a gallon or so of carb cleaner. It will take it all off, including paint
Jan
Mark Gilmore
'Thanks to all for the input on cleaning cylinders.Mark
#ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548 -- #ygrps-yiv-1768546923yiv4527789548ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp #ygrps-yiv-1768546923yiv4527789548hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp #ygrps-yiv-1768546923yiv4527789548ads { margin-bottom:10px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp .ygrps-yiv-1768546923yiv4527789548ad { padding:0 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp .ygrps-yiv-1768546923yiv4527789548ad p { margin:0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mkp .ygrps-yiv-1768546923yiv4527789548ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ygrp-lc { font-family:Arial;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ygrp-lc #ygrps-yiv-1768546923yiv4527789548hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ygrp-lc .ygrps-yiv-1768546923yiv4527789548ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity span { font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity span span { color:#ff7900;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548activity span .ygrps-yiv-1768546923yiv4527789548underline { text-decoration:underline;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548attach div a { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548attach img { border:none;padding-right:5px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548attach label a { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548bold a { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 dd.ygrps-yiv-1768546923yiv4527789548last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 dd.ygrps-yiv-1768546923yiv4527789548last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 dd.ygrps-yiv-1768546923yiv4527789548last p span.ygrps-yiv-1768546923yiv4527789548yshortcuts { margin-right:0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548attach-table div div a { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548attach-table { width:400px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548file-title a, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548file-title a:active, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548file-title a:hover, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548file-title a:visited { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548photo-title a, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548photo-title a:active, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548photo-title a:hover, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div.ygrps-yiv-1768546923yiv4527789548photo-title a:visited { text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 div#ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg #ygrps-yiv-1768546923yiv4527789548ygrp-msg p a span.ygrps-yiv-1768546923yiv4527789548yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548green { color:#628c2a;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 o { font-size:0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548photos div { float:left;width:72px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548reco-category { font-size:77%;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548reco-desc { font-size:77%;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 .ygrps-yiv-1768546923yiv4527789548replbq { margin:4px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg select, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 input, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg pre, #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 code { font:115% monospace;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-mlmsg #ygrps-yiv-1768546923yiv4527789548logo { padding-bottom:10px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-msg p#ygrps-yiv-1768546923yiv4527789548attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-reco #ygrps-yiv-1768546923yiv4527789548reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-sponsor #ygrps-yiv-1768546923yiv4527789548ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-text { font-family:Georgia;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-text tt { font-size:120%;} #ygrps-yiv-1768546923 #ygrps-yiv-1768546923yiv4527789548 #ygrps-yiv-1768546923yiv4527789548ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1768546923
Jan
David Stroud
'? Giday, Lads. I've been off the list for some time and could use a some input from anyone that may be able to help. I'm having to give up on my Fairchild 51 project. Yes, a 51...not a PT nor a 24. A google search will show a few examples and really it was the little brother to the Fairchild 71 or FC2W2. Bob Reeve started up Reeve Aleutian Airlines with a 51. 44' wingspan, 7' wing chord, high / folding wing, wood wing, tube fuselage and all fabric covered. Single seat up front, two singles behind it and one two place bench behind that, plus a large baggage bay. Gross would be about 4,000 lbs and empty about 2,200. Engine was a Wright J5 of some 220 hp but I have a Housai ( Nanchang, similar to Yak) 285 hp Radial with controllable metal prop and stainless exhaust. About 300 hrs on 1st overhaul. The fuselage is complete and on the gear...Vultee BT13 wheels, new tires and tubes from Desser. Empennage is finished, needs rear struts. I'm in posession of what might the the last NOS lift strut blanks from a Norseman. Tail wheel is done. Two and 1/2 of the 4 box type wing spars are done. Rudder pedals and brakes are done. Three copies of the plans are on hand. I have an original control column assy from a 1929 Fairchild here. Panel is almost done, no instruments. Full air start system from Jim Kimball is on hand but not instaled. All important wing folding fittings are done...all the hard stuff is done. Will sell to interested party for far less than my $$ invested. If anyone is interested in this project, pls. email me direct dstroud at xplornet.com ( check that spelling) and we can talk. If anyone knows of a group or club that might take on such a project, pls. let me know. It would likely qualify as the largest homebuilt done, excluding those professionally finished by teams of pros, Burt Rutan and the like. The project is in Ottawa, Canada just North of New York State. I could assist with transport...border crossing is not a problem. Thanks lads.. Dave Stroud '
