Re: Tach drive tang
Tach drive tang
'I'm trying to find the short "I" tang that goes between the engine tach drive and a dual drive unit. Little short gizmo with an "I" tang at both ends. Ain't had much luck. Anyone here can help?'
Re: Tach drive tang
'Hmmm.....maybe I'm complicating this too much. I'm trying to Drive a second tach in the front cockpit of my Great Lakes. My Ranger appears to have a dual tach drive. Does anyone have that type of setup? It looks like all I have to do is pull the cap off the unused tach drive adapter and install the cable to the second tach. Can it really be that simple?
Any advice?
--- In fairchildclub@yahoogroups.com,
"Mike" wrote:
Any advice?
ccmueller001
Re: Tach drive tang
'My Ranger has duel tach drives on the accessory housing, with a tach cable from each to the 2 tachometers. Sounds like it really is that simple.
Charles
Charles
> Any advice?
Sid Nethery
Re: Tach drive tang
'Yes Mike, I think it is that simple. My w-670 has the same arrangement.
Sid
Sid
> Any advice?
Re: Tach drive tang
'Mike,
For the Ranger powered PT-19, one cable is routed to each cockpit. For the 24, only one is needed, the other is capped off. The "gizmo" you are looking for is part of the cable assembly. Have one fabricated to match the existing one you have installed and route it to the second tach.
Mike Denest
"He's crazy Lew, he builds toy airplanes".
- Capt. Frank Towns
Flight of the Phoenix
Sent: Wednesday, July 25, 2012 1:00 PM
Subject: [fairchildclub] Re: Tach drive tang
Charles
Mike Denest
- Capt. Frank Towns
Charles
> Any advice?
