'Need a source for the copper crush gaskets that seal the oil screens on a PT-19, 200 hp, Ranger engine
There are two:
a large one where the spring is enclosed, higher on the engine.
a small one lower on the engine.
Any suggestion would be appreciated
Thankx'
Re: PT-19 RANGER L-440 COPPER OIL SCREEN CRUSH GASKETS
'Fresno Air Parts has them. 559-237-4863. You might have to buy the gasket kit which contains them all at $98 dollars.
Sent: Monday, May 14, 2012 6:16 AM
Subject: [fairchildclub] PT-19 RANGER L-440 COPPER OIL SCREEN CRUSH GASKETS
There are two:
Thankx
'Aren't they the typical AN-900 gasket? measure the size and order from Aircraft Spruce and Speciality
> From: ClairC
> There are two:
> Thankx
'I just got some of the larger 2 1/8" ID crush gaskets from Fresno Airparts. Phone 559 237 4863. Offer to send them a check ahead of time or they will be shipped COD by UPS for an additional $20. They cost about $8 each.
Charles
Charles
> There are two:
> Thankx
