Re: Ranger Valve Spring
fairchild24j
Ranger Valve Spring
Post by fairchild24j »
'How can I diagnose, confirm or deny that I have a broken valve spring on my 200 H.P. Ranger engine?'
Airy Millet
Post by Airy Millet »
'just open the rocker cover (the lowest long carter of your engine).
loss of compression may happen as the valve may have been damage when touching the piston and then not seating well on the valveseat!
with broken spring, the valve may loose totaly its sleeves and cups, and be thrown into the cylinder, crushing everything within the cylinder (hole in piston, etc..)
hope, this will not be the worst case for your engine!
Airy
Date: Tue, 7 Feb 2012 11:40:48 +0000
Subject: [fairchildclub] Ranger Valve Spring
