Re: Entry Step
tandemtrainer
Entry Step
'Does anyone have a source or supply of the cast entry steps for both sides of my '46 F-24R. Somebody in the past must have liked mine a lot. Also, interior door handles, I'm missing one(r.h. inside door) and the others are in sad condition.
Steve Lawlor N1010W'
Patricia Banks
Re: Entry Step
'Door handles can be purchased from www.lebaronbonney.com or www.oldmoparts.com. Mid 30s vintage chrysler I believe.
'--- On Fri, 10/14/11, tandemtrainer wrote:
Subject: [fairchildclub] Entry Step
Date: Friday, October 14, 2011, 1:28 PM
Steve Lawlor N1010W
Kevin Trumpore
Re: Entry Step
'what does this step look like? i have several old cast steps in the shop and hanger that we have no idea what they are for. they came with a lot of parts i obtained years ago from an old packrat friend that was moving
Kevin
Sent: Friday, October 14, 2011 1:28 PM
Steve Lawlor N1010W
Kevin
Steve Lawlor N1010W
Re: Entry Step
'I have one OE step plate, and 2 reproductions ( that I plan to use). I don't think that a scanner will do it justice so I'll take a picture (digital). I have a paper cutter with a 1 cm. grid that I will use as a back drop. The best that I can see is that they were originally casted the same, the the inner edge was cut away to allow it to fit around the inboard downward post, and the under side was cut away (recesses) slightly to fit around the teardrop of the step.
I think that in the later Fairchilds, they may or may not have been equipped with the pretty step plates. Both of the steps (teardrop portion) were not drilled for the mounting of the cast step plates. Telling me, that step plate weren't standard on all airplanes. Either that or both steps weren't OE on the airplane, per a 1948 accident.
Sent: Saturday, October 15, 2011 2:28 PM
Subject: Re: [fairchildclub] Entry Step
Kevin
Steve Lawlor N1010W
Kevin
Steve Lawlor N1010W
tandemtrainer
Re: door handles
'Thanks for the leads, but I tried both with no luck. I've also heard that '37 Studebaker handles would fit? I haven't found a source yet
Steve F24R46 N1010W
Steve F24R46 N1010W
> From: tandemtrainer
> Steve Lawlor N1010W
Kevin Trumpore
Re: door handles
'look in Hemmings Motor News. If you do not have a copy, most major book stores that also sell magazines have it available.
Sent: Sunday, October 16, 2011 5:07 PM
Subject: [fairchildclub] Re: door handles
Steve F24R46 N1010W
Steve F24R46 N1010W
> From: tandemtrainer
> Steve Lawlor N1010W
frank gochenauer
Re: door handles
'Plymouths from the late 30's should do what you want. You can find them in Hemmings Motor News magazine.Frank GTo: fairchildclub@yahoogroups.com
Date: Sun, 16 Oct 2011 21:07:21 +0000
Steve F24R46 N1010W
Steve F24R46 N1010W
> From: tandemtrainer
> Steve Lawlor N1010W
Re: door handles
'I can't remember which I have? A door handle or window crank. I'll take a look. Is it a fairly straight hangle with a slight curve at the end, and has bevel edge to it? I may only have a window crank.
Oh, I have a photo of N1010W at Tahlequah OK in "73".
Sent: Sunday, October 16, 2011 2:07 PM
Steve F24R46 N1010W
Steve F24R46 N1010W
> From: tandemtrainer
> Steve Lawlor N1010W
Tom_Downey
Re: Entry Step
'E-Bay Item
120798958677
front fueling step for a 24-C8C or eairlier'
120798958677
Tom_Downey
Re: Entry Step
'second step is reproduction
E-Bay number 120800548412
'--- In fairchildclub@yahoogroups.com, "Tom_Downey" wrote:
> E-Bay Item
> 120798958677
