'According to the STC for the PT-26 it should have a Ranger L-440-C-5 engine (200 hp) installed. Looking things over closely I find I have the -2 (175 hp) engine installed. Phooey!
 Two questions:
 Is there a 337 out there for using the -2 engine? I would prefer the additional 25 hp as I fly out of a 1700 ft strip with lots of orchards all around, though the elevation is just 175 ft MSL. But avoiding engine work at this time would be nice too.
 And: what is involved in converting a -2 to a -5 engine? Is it just pistons?
 Any input will be appreciated.
 Charles'
						Re: PT-26 with 175 hp Ranger
				Curt Kinchen
'It's likely that your -2 engine isn't and really is a 200HP.  The difference
between 175 and 200 HP is the domed pistons bumping the compression ratio
and the ignition timing(25BTC for the 200 vs 22 for the 175). If you have a
Stromberg carb the settings are different.
> Two questions:
> pistons?
> Charles
Curt Kinchen
ptcurt@gmail.com
				ccmueller001
'I just checked for a domed piston (with a carefully bent coat hanger through a spark plug hole) and found a domed piston. It appears to have about a 3/8" rise from side to center. Is this about right for a 200 hp (-5 Ranger) engine?
Perhaps I have a 6-440C-5 engine with a 6-440C-2 data plate?
Any suggestions on which way to go from here (to keep the faa happy and not asking my mechanic to stick his neck out)?
Charles
Charles
> > Two questions:
> > pistons?
> > Charles
> Curt Kinchen
> ptcurt@...
				Gene Haines
'There should be an entry in the engine log if the engine has non standard piston for the 175 HP Ranger..
To: fairchildclub
Sent: Fri, Sep 16, 2011 12:34 pm
Subject: [fairchildclub] Re: PT-26 with 175 hp Ranger
Charles
To: fairchildclub
Charles
> > Two questions:
> > pistons?
> > Charles
> Curt Kinchen
> ptcurt@...
'You are an optimist!
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Gene Haines
Sent: Friday, September 16, 2011 1:04 PM
Subject: Re: [fairchildclub] Re: PT-26 with 175 hp Ranger
To: fairchildclub
Charles
To: fairchildclub
Charles
> > Two questions:
> > pistons?
> > Charles
> Curt Kinchen
> ptcurt@...
'I believe Sgt. Schultz said it best.  http://www.youtube.com/watch?v=34ag4nkSh7Q
Mike Denest
Sent: Friday, September 16, 2011 2:54 PM
Subject: RE: [fairchildclub] Re: PT-26 with 175 hp Ranger
To: fairchildclub
Charles
						Mike Denest
To: fairchildclub
Charles
> > Two questions:
> > pistons?
> > Charles
> Curt Kinchen
> ptcurt@...
				ccmueller001
'Schultz was right - nothing found in the log books.
> Â
> Mike Denest
> From: Cy Galley
> Â
> From: ccmueller001
> To: fairchildclub
> Charles
> > > Two questions:
> > > pistons?
> > > Charles
> > Curt Kinchen
> > ptcurt@
