'On Mar 19, 2008, at 8:09 AM, fairchildclub@yahoogroups.com wrote:
> The problem with the external power socket is trying to find the
> plug it mates to! So, you can wire it in but it is basically useless.
Re: Digest Number 1820
'I have one that was purchased from Aircraft Spruce
'The Fairchild external plug is a bit like an overgrown plug for a 110
volt wall socket, only the 2 prongs are rods, one 3/8 inch diameter,
the other 5/16 inch diameter. They are spaced about 1 1/4 inch
center-to-center, and are each about 1 1/4 inch long.
Buhwana - does this sound like what you found at Aircraft Spruce? (It
isn't anything like the common Piper or Cessna plugs that I've seen.)
