'Hartzell fliers:
Its time to replace the diaphragm on my Hartzell HC12x20-8 prop. It
works well but has been seeping oil since a few weeks after its last
replacement which makes for a dirty airplane (although rust-free!).
Does anyone flying behind the Hartzell have any good advice on
keeping it dry? Ive contacted Hartzell and they werent able to offer
any advice other than to avoid over-tightening the clamp bolts (which
cracks off the ears). Last time we used a light coat of sealant but
Im not sure if that helped or hurt. It seems that the rubber
compresses over time and the clamp bolts lose torque; I am going to
leave the prop off for a few days and re-torque before finishing
reassembly to see if that helps.
:Dan Michael
:NC81323'
Re: Hartzell HC12x20 diaphragm leaks
'Dan,
Expect very little help from Hartzell. All the folks that knew the prop have died or retired. You can give Tom Goodlett a call in Texas. He has about 20 years experience with the Hydro. Has been inside and replaced items over the years.
Tom Goodlett
817-790-3190
Jamie
Aircraft Restoration & Repair
Kelly Airpark (CO15)
Hm/Hgr 303-648-0130
Never fly anything that doesn't have the paint worn off the Rudder Pedals.
Tom Goodlett
817-790-3190
Jamie
Hm/Hgr 303-648-0130
Sent: Sunday, April 08, 2007 3:39 PM
Subject: [fairchildclub] Hartzell HC12x20 diaphragm leaks
Hartzell fliers:
:Dan Michael
:NC81323
