'Hello All,
I am in the process of rebuilding my 24G after ground looping
it, and I am planning to replace the free-pivoting tailwheel with a
steerable tailwheel.
In the process of looking into how this might be done, I've been in touch
with Hal Bishop, who also has an early model 24 and is attempting the
same conversion.
He obtained a steerable 24 tailwheel strut from Charlie Bell, and has
discovered that fitting that strut into the early airframe will take
some doing... it doesn't just bolt in. A lower frame member interferes,
and the top attach bolt is in a different location. In addition, one
must add the
bellcrank mechanism behind the seats to carry the tailwheel control
cables back.
I saw one pre-war 24 with a Scott tailwheel at a fly-in in 2003, and
took some pictures.
(See the following link for pictures of it and of my aircraft)
http://members.cox.com/dcasali/
From the pictures the Scott installation looks very straightforward.
I'm wondering if any of you have a 337 for this or know anyone who has
done a similar conversion?
Also, is there anything you would watch out for if you were attempting
this conversion?
Thanks in advance...
Dan Casali
Dan Casali
MacWizard
Box 1286 Ketchum, ID 83340
208.726.5120
Re: Fairchild 24G/H tailwheel conversion -- 337's and/or info soug
'I had seen this very conversion (Scott 3200) on a F24, liked it,
bought records on CD from FAA, no mention of conversion in records. I
won't say anymore on that one.
That is most correct...a steerable unit won't replace a swiveler.
Saw this performed on an H. They got it in there but there is NO room
to spare. The steering horns have to be shortened, the upper
mountpoint welded and altered, and some questionable cable routings.
It works but still appears a marginal solution. That Scott 3200 looks
like a final word to the issue.
Hal Bishop? Doesn't he have Stampes?
'--- In fairchildclub@yahoogroups.com, Dan Casali wrote:
> Hello All,
touch
the
> same conversion.
has
interferes,
one
> must add the
> cables back.
and
> took some pictures.
straightforward.
has
attempting
> this conversion?
> Dan Casali
> Dan Casali
> MacWizard
> 208.726.5120
Re: Fairchild 24G/H tailwheel conversion -- 337's and/or info sought
'Wow, I never would have thought of ordering the FAA CD on someone else's
aircraft... that is a great idea.
And thanks for the detailed info on the conversion difficulties.
On the Scott, the only downsides I can think of are the torsional load
on the rudder, and the effect on weight and balance putting that
assembly a foot or so farther back. I noticed the aircraft I saw had a
Hamilton Standard prop on its nose, so no issue for them.
I've only talked to Hal once; I caught him just as he was leaving town
until the end of this month. Don't know if he has Stampes. He did sign
up for our list, and should be back on 1 December.
Dan Casali
Dan Casali
ranger440c5 wrote:
[Non-text portions of this message have been removed]'>
'I have always wondered why people request 337's for modifications. It
is public information. And since they went to CD it is about$5 (might
be $7.50 now) you order online at the registry inquiry page with a
credit card. All you need is an N number. If you see an airplane or
hear of a modification just get the N number and order the CD. I have
done this on MANY aircraft, especially older inactive aircraft. They
are still registered but may not really exist. If you find an
interesting modification before 1957(IIRC?) it is approved data,
meaning a simple 337 with no FAA signoff and a log entry.
else's
load
had a
town
sign
> Dan Casali
records. I
room
routings.
looks
'Yes, we do have Stampes. We have been in the Stampe world for about 32 years. At present we have 2 projects. One we will put a LOM up front. The other, an orginal Renault. Hal and Jeanene Bishop
> From: Dan Casali
> Date: 2006/11/19 Sun PM 07:00:32 CST
> Subject: Re: [fairchildclub] Re: Fairchild 24G/H tailwheel conversion --
> Dan Casali
'Say, didn't you have a Standard Waco cabin to work on? S-7? Don't tell
it's done!
it's done!
