'Being quite new to Fairchild's I was wondering if anyone could help me
with the following question? I have seen where some of the older F24's
(the one I'm interested in is 1937) have had their lower horsepower
Ranger engine upgraded to 200HP. Is this an engine change or an engine
modification? How is it approved with the FAA? By Service Bulletin or
337?
Thanks in advance for your combined wisdom!!'
Re: Ranger upgrade to 200 HP
windshieldguy2000
'John: The Denests will have all the technical information about the
upgrade from 175 to 200 hp. To my rather pedestrian level of
knowledge, the heart of the upgrade is the carburetor, pistons, and
rings. My engine was converted (upgraded?) during an overhaul in 1964
and the only documentation was a logbook entry, complete with part #'s
and a reference to all work being done in accordance with the Ranger
Overhaul manual. I would assume that a 337 would be required now.
Good luck with your airplane, the short-nosed F-24 with a 200hp engine
performs really well. Oops, let me clarify that statement: The short-
nosed F-24 with a 200hp engine performs better than the post WWII
models, all other factors (prop, engine condition, etc.) being equal.
Best Wishes,
Brad Donner'
Best Wishes,
Brad Donner'
'That is true I had a C8 F with a two hundred conversion among other things,
except it's very crowded at the firewall
Joe will need to know the serial number of the case. There may be a problem
if it is the original power plant.
_____
On Behalf Of windshieldguy2000
Sent: Tuesday, March 21, 2006 10:35 PM
Subject: [fairchildclub] Re: Ranger upgrade to 200 HP
Best Wishes,
Brad Donner
_____
YAHOO! GROUPS LINKS
* Visit your group "fairchildclub
" on the web.
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
_____
_____
Best Wishes,
Brad Donner
_____
YAHOO! GROUPS LINKS
" on the web.
Terms of Service.
_____
ethyl222000
'Thanks for both of your inputs.
Allthough I have not yet seen this particular aircraft the info I do
have says the engine is a Ranger 440. Which I assume to mean the
original engine has been replaced. I will learn more from the owners
in a week or so & we will go from there.The airframe serial number is
#3229 N12120 in Ohio.
John
.--- In fairchildclub@yahoogroups.com, "Bob Haas"
John
things,>
problem> except it's very crowded at the firewall
the> On Behalf Of windshieldguy2000
1964> upgrade from 175 to 200 hp. To my rather pedestrian level of
#'s> and the only documentation was a logbook entry, complete with part
Ranger> and a reference to all work being done in accordance with the
engine> Overhaul manual. I would assume that a 337 would be required now.
short-> performs really well. Oops, let me clarify that statement: The
equal.> nosed F-24 with a 200hp engine performs better than the post WWII
> Best Wishes,
> Brad Donner
> _____
> YAHOO! GROUPS LINKS
> " on the web.
> Terms of Service.
> _____
Mike Danielle
'Not necessarily, John. The engine will have a data plate on the right side
that will tell you what model Ranger is installed. The 440C-5 is the 200hp
version.
version.
Sent: Thursday, March 23, 2006 8:11 AM
> John
> things,
> problem
>> _____
> the
> 1964
> #'s
> Ranger
> engine
> short-
> equal.
>> Best Wishes,
>> Brad Donner
>> _____
>> YAHOO! GROUPS LINKS
>> " on the web.
>> subject=Unsubscribe>
>> Terms of Service.
>> _____
