'Warner owners,
I have just uploaded two photos of Warner 165/185 engine rings with
the lip mod. This mod was created by Curtiss Pitts back in the late
40's to stop the cracking that occurs around the lib opening. If you
are in the process of restoring a ring cowl, you may want to consider.
I have a cowl in St. Louis being modified. This cowl has 9+ cracks
around the ring opening.
Jamie S. Treat'
Re: Warner Engine Cowl Ring Mod
Alan Macon
'Jamie
Where are the up loaded pictures on the ring located?
Thanks Alan NC 28525
--- In fairchildclub@yahoogroups.com, "Jamie S. Treat"
> Warner owners,
> Jamie S. Treat
OldOOwl@aol.com
'Jamie....
Who in St. Louis is doing the fix?
Thanks!
Richard Hawley
NC19105
Thanks!
Richard Hawley
NC19105
'Richard,
Here is the POC. He has two Warner cowls and a set of wheel pants. All are
in bad shape.
STL Aircraft Metal Arts
http://www.liming.org/aircraftmetalarts/index.html
Timothy P. Wood A&P, IA
502 Bellerive Blvd.
St. Louis, MO 63111
(314)541-0540 (c) or (314)353-2359
Aircraft Restoration & Repair
Kelly Airpark
http://www.kellyairpark.com
HM/Shop 303-648-0130
JamieTreat@direcway.com
in bad shape.
502 Bellerive Blvd.
St. Louis, MO 63111
Kelly Airpark
Sent: Sunday, February 05, 2006 1:28 PM
Subject: Re: [fairchildclub] Warner Engine Cowl Ring Mod
> Jamie....
> Thanks!
> Richard Hawley
> NC19105
