'Hi,
I hope somebody out there who is a Ranger guru can identify what Ranger
engine the rings I have came from. I have ring sets for two pistons that are
2-3/4" o.d. when compressed. That's right they are small. The ring numbers are
one 1571 top compression; two 1572 for center compression, and one 1574 for
oil control.
The rest of the info on the packages reads "V-32 Engine Type D2." They were
manufactured by Ranger Aircraft Engines, Farmingdale, N.Y.
I am curious about what engine they are for and what the engine was used
for. Anybody know?
Earl W. Swaney
Fairchild 24W40
N28645
_earln28645@aol.com_ (mailto:earln28645@aol.com)
Re: Stange Ranger piston Rings
Pete and Cindy Crawford
'Earl,
Ranger made a V-configuration engine that was used as an APU in bomber aircraft (B-29 for sure). The rings could possibly for that application.
Pete Crawford
Pete Crawford
Sent: Friday, May 27, 2005 7:26 PM
Subject: [fairchildclub] Re:Stange Ranger piston Rings
Hi,
oil control.
for. Anybody know?
Earl W. Swaney
Fairchild 24W40
N28645
a.. To visit your group on the web, go to:
rangerrobertmn
'Earl,
I have the engine that those rings are for. It was manufactured by
a company that Sherman Fairchild was associated with. It is a twin
cylinder V. It has two carburators and a fuel pump and an oil pump
and a large magneto with shielded wires. It sounds a LOT like an
old Harley.
I have a friend that used to fly B-29s. He said that the pilot
would call to someone in the back of the plane to 'start the putt-
putt'. Someone would start this engine (which has a huge 24v
generator attached). The engine throttle has two detent positions,
START and FULL THROTTLE. At full throttle, it would produce enough
power to start the main engines.
It has a rope on a notched pulley for a starter. I don't know if
the original may have had a strater/generator.
If you ever get to my neck of the woods, I would be happy to demo it
for you. We live in Stillwater, MN, east of St. Paul, 2 miles from
Wisconsin.
old Harley.
Wisconsin.
'--- In fairchildclub@yahoogroups.com, EarlN28645@a... wrote:
> Hi,
Ranger
pistons that are
ring numbers are
one 1574 for
> oil control.
D2." They were
was used
> for. Anybody know?
> Earl W. Swaney
> Fairchild 24W40
> N28645
> _earln28645@a..._ (mailto:earln28645@a...)
danMichael
'On Sunday, May 29, 2005, at 07:54 AM, rangerrobertmn wrote:
http://www.rootsweb.com/~ny330bg/puttputt.htm
Apparently the B-29 APU was kept running during takeoffs and landings
to provide backup power for the hydraulic brakes, too, since the
primary generators would go offline at low RPM. I found a reference
that the Ranger APU was also used on the B-25, but I cant verify it.
:Dan
:NC81323'
Is this it?> Earl,
> old Harley.
> Wisconsin.
> Bob Waldron
:Dan
:NC81323'
rangerrobertmn
'Dan,
That's my engine. Thanks for the GREAT link. Now that I am armed
with this info, I will have to set mine up so that I can demonstrate
it at fly-ins. Thanks again for the info. Ain't the internet GREAT?
1939 Fairchild 24K
Stillwater, MN
1939 Fairchild 24K
Stillwater, MN
> > Earl,
by
twin
pump
> > old Harley.
putt-
positions,
enough
demo it
from
> > Wisconsin.
> > Bob Waldron
> Is this it?
landings
reference
it.
> :Dan
> :NC81323
norbymac20@sbcglobal.net
'Dan I flew B-25s and I don't remember having a APU on board but there may
have been some special applications. Lucky
Sent: Monday, May 30, 2005 2:05 AM
Subject: Re: [fairchildclub] Re:Stange Ranger piston Rings
>> Earl,
>> old Harley.
>> Wisconsin.
>> Bob Waldron
> Is this it?
> :Dan
> :NC81323
