'Been thinking about replacing the tires on my PT-19. They're not that bad, just a peace of mind thing. What is the proper size and a good source for them? Are there any mounting concerns? I've put several hours on the airplane during the last couple of months, sure a great time to fly in South Texas!
Thanks!
Robert Hensarling
Re: tires
John Berendt
Re: tires
'Bob,
The size is 6.50x10 if you have Hayes wheels it is a lot of fun to get the
old tires off and the new ones on.
John Berendt
John Berendt
Sent: Sunday, September 28, 2003 10:24 AM
Subject: [fairchildclub] tires
Texas!
> Thanks!
> Robert Hensarling
Re: tires
'Bob,
As John stated, 6.50 x 10. I get mine from Desser Tire.
http://www.desser.com/ Shipping is free. Get new tubes at the same time,
keep old for spares.
I am trying to get Desser to make the old Diamond type.
As for dismount and remount. I take mine to a real tire shop, old time shop.
Forget Sears and Discount tire. Big-O has come thru at times. Call around to
the ones that mount ATV/RV tires. They have the smaller mounting tools for
the Hayes. They can also balance them for you with the adhesive weights.
Jamie
Jamie
Sent: Sunday, September 28, 2003 10:48 AM
Subject: Re: [fairchildclub] tires
> Bob,
> John Berendt
> From: "robert hensarling"
> To:
source
South
> Texas!
> > Thanks!
> > Robert Hensarling
EarlN28645@aol.com
Re: tires
'Hi
It isn't any fun to put tires on the Hayes wheels. I take my wheels and
tires and tubes to my local tire shop. They have a four-point hold down system
for rims instead of the center one which is too big for the Hayes wheel. The
charge is nominal and if you tell them they are airplane wheels, they will
probably take extra care as my tire shop does. Hope this helps.
Earl W. Swaney
N28645'
Earl W. Swaney
N28645'
lov2fly28525@cs.com
Re: tires
'Order them from Desser. Also, if you have a tire shop that does aluminum
rims, they will have a machine that will work on Hayes wheels. Its worth the 10
bucks or so. I use Les Schwab Tire Co. here in Idaho.
Al Rice
NC28525
F-24W41A
Al Rice
NC28525
F-24W41A
Curt Kinchen
Re: tires
'Hey Robert...concur with what everone else has said, except the first
time I did it a couple of tire shops weren't equipped and
couldn't/wouldn't do it. Ended up at a shop that does race cars and
dragsters, should be one like that in your neck of the woods. As
long as they have the right machine, it shouldn't be a problem. Be
sure to tell them to be careful and they are for an antique airplane
and you'll be fine.
The last time I put tires on the PT it was at a Les Schwab(big chain
in the west). Both times the shops I went to did it for free 'cus
they thought it was cool.
Also, consider retreads, they're much cheaper and readily available
as they're the same size as Cessna 310(and probably other) tires.
Just make sure to tell them to match the sidewalls if you want them
that way otherwise you can end up with mixed brands.
Curt
--- In fairchildclub@yahoogroups.com, "robert hensarling"
and you'll be fine.
Curt
that bad, just a peace of mind thing. What is the proper size and a> Been thinking about replacing the tires on my PT-19. They're not
'> Thanks!
> Robert Hensarling
Buell Powell
Re: tires
'Robert,
I have some extra tires if you need some. All of them have
never been mounted but I don't know how long ago they were made. They are
all 6.50X10.00. Two are Goodyear Flight Custum which I need $90.00 for two
plus shipping. One is a Mcquary Type 111 wich I would sell for $25.00 plus
shipping.
Buell Powell
.----- Original Message -----
Sent: Monday, October 06, 2003 6:45 PM
Subject: [fairchildclub] Re: tires
shipping.
Buell Powell
'> Hey Robert...concur with what everone else has said, except the first
> and you'll be fine.
> Curt
> > Thanks!
> > Robert Hensarling
robert hensarling
Re: tires
Sent: Tuesday, October 07, 2003 2:46 PM
Subject: Re: [fairchildclub] Re: tires
Buell, thanks for the info. I'll keep it in mind. Will probably re-tire (the PT-19, not me) during the winter.
Robert
Robert,
shipping.
Buell Powell
> and you'll be fine.
> Curt
> > Thanks!
> > Robert Hensarling
Yahoo! Groups Sponsor
ADVERTISEMENT
