'Ok, so I got the system all flushed out I think (one gallon denatured alcohol). Injected it from each wheel till it ran out the clear hose coming out of the top of the tank. Then let all of that gravitate back down and out the brake fitting. Did this twice, and the alcohol finally turned clear (ish). Started in with the Dot 5 on the right till fluid came out the hose on top, closed that one off and started on the left, got halfway finished and ran out of Dot 5 (which of course has to be special ordered when you live in Uvalde, Texas. I did sneak into the cockpit and press on the right brake to see if there was any resistance, went right to the floor. Will continue when more dot 5 is available. I haven't sealed any connections yet, and I'm positive that I'll regret that eventually. Will more than likely have to do the entire procedure again in a couple of weeks. BUT..... it's sorta fun.
Robert Hensarling
rhrocker@hilconet.com
www.mesquiterocker.com
Uvalde, Texas
Re: braking up is hard to do
'There is a definite learning curve with bladder brakes and DOT 5. You might
want to try LOCTITE 542 ON ALL threads it is used as a thread sealant.
(hydraulic sealant) Walt
Sent: Sunday, December 23, 2001 7:40 PM
Subject: [fairchildclub] braking up is hard to do
it's sorta fun.
> Robert Hensarling
> Uvalde, Texas
