One other thing.....On bleeding the brakes, the T.O. says to pressure the system with 5 PSI. I can't do this as the cap on the brake fluid reservoir is drilled and vented. Do I need a non-vented cap for initial bleeding? For full time? Do I not need to pressurize the system?
Any help would be appreciated.
Steve in OK.
From: fairchildclub@yahoogroups.com on behalf of Steve Link steven_link@msn.com [fairchildclub]
Sent: Sunday, November 5, 2017 12:51 PM
Subject: Re: [fairchildclub] PT Brakes
Just loaded the pix under the album PT Brakes.....
Sent: Sunday, November 5, 2017 12:45 PM
Subject: [fairchildclub] PT Brakes
Just got thru rebuilding my master cylinders…..took all of about 30 minutes after removing them from the plane. Thankfully my cylinders were in excellent shape. Pix to follow if they don’t show on this e-mail.
Not sure why there are two different types. The LH one looks like it has a spot welded saddle for the fitting, and a longer end sweated on with an internal stop, possible a cheaper wartime type. RH has a tag on it with 38776 stamped on it….seems much more solid.
Used Rockauto Raybestos MK-190 kits….
Sent: Sunday, October 29, 2017 8:00 AM
Subject: RE: [fairchildclub] PT-26
There is a rebuild kit for them if all you need is the internals and your cylinder is OK. The last answer I got was the Rockauto Raybestos MK-190 kits and appear to be identical to the parts for the PT-19/23/26 cylinder with the one inch bore.
Sent: Saturday, October 28, 2017 10:36 AM
Subject: Re: [fairchildclub] PT-26
Thank you very much, I will give them a call
Sent from my iPad
On Oct 28, 2017, at 11:26 AM, Jay Herrin jayherrin@bellsouth.net [fairchildclub] wrote:
David... try White Post Restorations. 540-837-1140
They did the master cylinders on my OTW and I’m am very happy with their work!
Jay
Sent from my iPad
On Oct 28, 2017, at 10:59 AM, David Stout aviator5@bellsouth.net [fairchildclub] wrote:
Finally found a couple of decent expander tubes for this airplane, however was disappointed to find both master cylinders leaking like a sieve.....removed them and took them apart. Bore looks fairly decent but needs new seals, cup style seals...anybody have any idea where I might find these? Thanks for any ideas you may have.
David Stout
