'I had no reason to ask about the 150's, but I imagine that they would have them.  Try "Herber Aircraft Service @ 800-544-0050 or 310-322-9575"  WEBSITE  www,herberaircraft.com    I was surprise that I also received a letter of certification as to the date of manufacture.  The 8 mounts (100PDL-2) that I received were made this year (2/13).  I paid around $20.00 each.   For this first time I know that they are new, and not something that the Military considers to be too old even for them. Bob
     On Saturday, December 7, 2013 11:31 PM, Gene Haines  wrote:
Hmmm.  Only going to do the floating panel or the surround?  We have four on each assy.  That would be 32 rivets per cockpit.  For each cockpit there would be eight 100APL's. The old ones look better all the time.
 Maybe a new heated hangar.  That will bring the price up a bit.
 Just a bit of humor
  To: fairchildclub
  Sent: Sat, Dec 7, 2013 9:44 pm
  Subject: Re: [fairchildclub] Shock mounts for instrument panel.
        That sure sounds good to me.           I noticed on the Aircraft Spruce catalog, the 100APL "New surplus item - like new mfg".           I have several of the 1" square mounts, but I have no idea as to the date of manufacture.  So I bought 8 of the 100 APDL that were  certified as new.  The price was quite a bit higher than what you paid.         How I need to remove 16 1/8" rivets.  And it happens to be too darn cold.  Today's high, maybe 29 deg.         Bob
             On Saturday, December 7, 2013 1:24 PM, Gene Haines  wrote:
After some research I find that the original mounts for the PT-26 instrument panels that we have, have 150 series and steel stamped on the square metal plate. Looking at Lord documents I find the 150P- ?? is the correct mount.  The ?? are to indicate the weight to be held.
 Looking at Aircraft Spruce I find that they have the square 150P for 24 lbs with part number 08-07183.  With the old gyros, the floating panel will be quite heavy.  The mounts they show are a little less than $12.00 each
 The PT-19 panels we have, have the 1" platform mounts. These are also available at Aircraft Spruce.
 Gene Haines
  To: fairchildclub
  Sent: Sat, Dec 7, 2013 2:03 pm
        I give you a quickie on the dimensions of the mounts that I have looked at. (some of the suffixs may differ)        100APL Series  -  1x1"  centers on the bolt pattern.                      Rubber dia - 1".          Bolt dia - 0.166"                 150APL Series  -  1.375X1.375"centers on the bolt pattern.         Rubber dia - 1.5".       Bolt dia - 0.257"                 If you can use the 150 series, I am happy for you.  The PT-19 I worked on  many years ago used the 100 series.  The F-24 that I have uses the 100 series.  I shutter at the thought of remaking the 8 pieces of the instrument cluster mounting system to accommodate the 150 series.                   I blue printer the F24 mounts years ago using what I could glean from the CD.  I scaled the  drawing to the point that I could print it,  cut it out and glue it to the metal that I was using.  All the cut lines, centers, dimensions, and bend lines were ready and waiting.                 I looked at a couple of the mounts that I couldn't use and there isn't enough material to allow for the 1.5" hole  so the rubber can go through the mount and the mounting flange to be flush against the mount.                 Lord has a E-mail account
http://www.lord.com/.  It has all the info for "PLATE FORM MOUNTS".                 Bob
                   On Wednesday, December 4, 2013 4:55 PM, Fritz Mehrer  wrote:
        Ok, guys, here’s is the info on the PT-26 instrument shock mounts…        Lord still makes the mounts, I bought a full set…  The Part Number is 150APL SERIES and you can choose the load factor you want to put in…  THEY ARE BEAUTIFUL.. and VERY expensive.         Fritz…  Ok, for this info, I am asking you guys to source out the PT-26 floating instrument panel I have been looking for……………………        Fritz        San Diego
fairchildclub@yahoogroups.com?]
On Behalf Of burnmcc@aol.com
Sent: Wednesday, December 04, 2013 10:34 AM
            Still waiting for description. I have quite a few different types I obtained from San Fernando surplus shops years ago.                                 Bill McC                -----Original Message-----
To: fairchildclub
Sent: Wed, Dec 4, 2013 11:47  am
Subject: Re: [fairchildclub] Shock mounts for instrument panel.                                                  Good luck on finding new 100APL (Square) shock mounts.  If I remember correctly, Lord doesn't make that model any longer.  If someone was to front a complete run of several hundred, they might do it.  That would be several thousand dollars.  Lord is at 1-877-asklord.                                 I did find some 100PDL(diamond) that look like a good substitute.  They are the diamond design, and they have the same dimension as the 100APL.  They only have 2 mounting holes on a diagonal, and they are the same distance apart 1.414".  That is the same as what you are looking for.                                   Aircraft Spruce has some 100APL's, and they are surplus, and not new.                                 The ones that I bought recent are 100PDL-2 (diamond) from "Herber Aircraft Service, Inc  PH 310-322-9575".                                 NOTE: did you notice the small holes either below the upper mounting screws, or above the lower mounting screws on the instrument cluster panel.  They work great for aligning the "L" shaped mounting brackets screw holes.  Use rib stich needle to align the "L" bracket to the main panel.  Then insert the screw.                                 Bob
 On Tuesday, December 3, 2013 4:03 PM, "burnmcc @aol.com"  wrote:
                                              Mike:   I have quite a few rubber shock mounts of different types, some of which sound like what you are looking for. Can you give me a  description and I'll check the stock.                                 Bill McClure
        #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259 --   #ygrps-yiv-1189613302yiv2423271259ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp hr { border:1px solid #d8d8d8;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp #ygrps-yiv-1189613302yiv2423271259hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp #ygrps-yiv-1189613302yiv2423271259ads { margin-bottom:10px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp .ygrps-yiv-1189613302yiv2423271259ad { padding:0 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp .ygrps-yiv-1189613302yiv2423271259ad p { margin:0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mkp .ygrps-yiv-1189613302yiv2423271259ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ygrp-lc { font-family:Arial;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ygrp-lc #ygrps-yiv-1189613302yiv2423271259hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ygrp-lc .ygrps-yiv-1189613302yiv2423271259ad { margin-bottom:10px;padding:0 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259actions { font-family:Verdana;font-size:11px;padding:10px 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity span { font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity span:first-child { text-transform:uppercase;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity span a { color:#5085b6;text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity span span { color:#ff7900;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259activity span .ygrps-yiv-1189613302yiv2423271259underline { text-decoration:underline;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259attach div a { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259attach img { border:none;padding-right:5px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259attach label { display:block;margin-bottom:5px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259attach label a { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 blockquote { margin:0 0 0 4px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259bold { font-family:Arial;font-size:13px;font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259bold a { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 dd.ygrps-yiv-1189613302yiv2423271259last p a { font-family:Verdana;font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 dd.ygrps-yiv-1189613302yiv2423271259last p span { margin-right:10px;font-family:Verdana;font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 dd.ygrps-yiv-1189613302yiv2423271259last p span.ygrps-yiv-1189613302yiv2423271259yshortcuts { margin-right:0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259attach-table div div a { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259attach-table { width:400px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259file-title a, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259file-title a:active, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259file-title a:hover, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259file-title a:visited { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259photo-title a, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259photo-title a:active, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259photo-title a:hover, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div.ygrps-yiv-1189613302yiv2423271259photo-title a:visited { text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 div#ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg #ygrps-yiv-1189613302yiv2423271259ygrp-msg p a span.ygrps-yiv-1189613302yiv2423271259yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259green { color:#628c2a;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259MsoNormal { margin:0 0 0 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 o { font-size:0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259photos div { float:left;width:72px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259reco-category { font-size:77%;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259reco-desc { font-size:77%;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 .ygrps-yiv-1189613302yiv2423271259replbq { margin:4px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg table { font-size:inherit;font:100%;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg select, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 input, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 textarea { font:99% Arial, Helvetica, clean, sans-serif;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg pre, #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 code { font:115% monospace;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg * { line-height:1.22em;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-mlmsg #ygrps-yiv-1189613302yiv2423271259logo { padding-bottom:10px;}   #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-msg p a { font-family:Verdana;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-msg p#ygrps-yiv-1189613302yiv2423271259attach-count span { color:#1E66AE;font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-reco #ygrps-yiv-1189613302yiv2423271259reco-head { color:#ff7900;font-weight:700;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-reco { margin-bottom:20px;padding:0px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ov li a { font-size:130%;text-decoration:none;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ov li { font-size:77%;list-style-type:square;padding:6px 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-sponsor #ygrps-yiv-1189613302yiv2423271259ov ul { margin:0;padding:0 0 0 8px;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-text { font-family:Georgia;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-text p { margin:0 0 1em 0;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-text tt { font-size:120%;}  #ygrps-yiv-1189613302 #ygrps-yiv-1189613302yiv2423271259 #ygrps-yiv-1189613302yiv2423271259ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1189613302
