'#ygrps-yiv-1673693241 p {margin:0;} Hi Jim, It has been quite a while--finally getting some time to work on the Fairchild. I still have the Hayes brakes--I fly my Taylorcraft with mechanical brakes most of the time so used to not have that much stopping power. Thanks to everyone for the information!
Hi BuellIts been a while!Take Jamie's advice, flush with Denatured Alcohol then use the Dot 5. Did you install Cleveland system or sticking to the Hayes brakes?Jim C.
On Monday, November 25, 2013 6:37 PM, Jamie Treat wrote:
Flush the entire system with Denatured Alcohol. JST From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of wsknettl@centurytel.net
Sent: Monday, November 25, 2013 4:38 PM
Subject: [fairchildclub] RE: Brake Fluid Hello Buell, The three fluids are very different and are not compatible with each other. Their systems are not cleaned and flushed with the same chemicals/fluids. I would suggest you do a little investigating on the traits and properties of each fluid type and make your own educated decision on which to use. Keep in mind that commonality is often the safest choice. Review these sites before making a final choice:Different Types Of Brake FluidDifference Between Dot3 and Dot4 Brake Fluid | Difference BetweenBrake_Fluid_Tech.pdf (application/pdf Object)DOT 3, DOT 4, and DOT 5 « Jim’s GarageBrake Fluid Facts Wes KIA in Wisconsin
---In fairchildclub@yahoogroups.com, wrote: Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines. Thanks. Buell Powell-1946 F24R
-- BHP
BHP
Re: Brake Fluid
Re: Brake Fluid
'I use DOT 5 in my 24 as well.
On Monday, November 25, 2013 2:20 PM, Jamie Treat wrote:
Buell, Yes you can use Dot 5. If you do, mark it in the log, highlight in yellow. Mark near the masters, cover is good place. Do the same for the struts. You do not want to mix Dot 3 or 5606. Bad news. JST From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Buell Powell
Sent: Monday, November 25, 2013 1:14 PM
To: Fairchild Club
Subject: [fairchildclub] Brake Fluid Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines. Thanks. Buell Powell-1946 F24R
-- BHP #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335 -- #ygrps-yiv-454916833yiv1082822335ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp #ygrps-yiv-454916833yiv1082822335hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp #ygrps-yiv-454916833yiv1082822335ads { margin-bottom:10px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp .ygrps-yiv-454916833yiv1082822335ad { padding:0 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp .ygrps-yiv-454916833yiv1082822335ad p { margin:0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mkp .ygrps-yiv-454916833yiv1082822335ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ygrp-lc { font-family:Arial;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ygrp-lc #ygrps-yiv-454916833yiv1082822335hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ygrp-lc .ygrps-yiv-454916833yiv1082822335ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity span { font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity span:first-child { text-transform:uppercase;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity span span { color:#ff7900;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335activity span .ygrps-yiv-454916833yiv1082822335underline { text-decoration:underline;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335attach div a { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335attach img { border:none;padding-right:5px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335attach label { display:block;margin-bottom:5px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335attach label a { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 blockquote { margin:0 0 0 4px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335bold a { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 dd.ygrps-yiv-454916833yiv1082822335last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 dd.ygrps-yiv-454916833yiv1082822335last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 dd.ygrps-yiv-454916833yiv1082822335last p span.ygrps-yiv-454916833yiv1082822335yshortcuts { margin-right:0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335attach-table div div a { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335attach-table { width:400px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335file-title a, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335file-title a:active, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335file-title a:hover, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335file-title a:visited { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335photo-title a, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335photo-title a:active, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335photo-title a:hover, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div.ygrps-yiv-454916833yiv1082822335photo-title a:visited { text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 div#ygrps-yiv-454916833yiv1082822335ygrp-mlmsg #ygrps-yiv-454916833yiv1082822335ygrp-msg p a span.ygrps-yiv-454916833yiv1082822335yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335green { color:#628c2a;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335MsoNormal { margin:0 0 0 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 o { font-size:0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335photos div { float:left;width:72px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335reco-category { font-size:77%;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335reco-desc { font-size:77%;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 .ygrps-yiv-454916833yiv1082822335replbq { margin:4px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg select, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 input, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg pre, #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 code { font:115% monospace;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-mlmsg #ygrps-yiv-454916833yiv1082822335logo { padding-bottom:10px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-msg p#ygrps-yiv-454916833yiv1082822335attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-reco #ygrps-yiv-454916833yiv1082822335reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-sponsor #ygrps-yiv-454916833yiv1082822335ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-text { font-family:Georgia;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-text tt { font-size:120%;} #ygrps-yiv-454916833 #ygrps-yiv-454916833yiv1082822335 #ygrps-yiv-454916833yiv1082822335ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-454916833
To: Fairchild Club
