'I had Consolidated Aircraft Coatings / Polyfiber mix me some of their EP-420 primer to match the green color used on the interior parts of the PT-26. The match was done to an interior part of the center section, so it had not been exposed to light. The color match was great, and being epoxy primer it is safe to use with covering chemicals. They suggest ordering from the factory. They will keep the formula on file. You can either specify my name PETE CRAWFORD or their identification EP420GREEN22.
Points of contact:Greg, email greg@conaircraft.comDavina, davina@conaircraft.com
Pete Crawford
Re: PT-26 interior primer available
Pete: Would you be willing to make a few color chip cards with some of the waste paint when you do some painting? My AT has a couple of different versions of the Bronze-Green primer on various pieces and I'd like to see what you came up with before I get serious about chasing formulas.
I don't mind sending you some $ for postage and a couple of small pieces for test stock.
Craig
Craig
'?? I had Consolidated Aircraft Coatings / Polyfiber mix me some of their EP-420 primer to match the green color used on the interior parts of the PT-26.?? The match was done to an interior part of the center section, so it had not been exposed to light.?? The color match was great, and being epoxy primer it is safe to use with covering chemicals.?? They suggest ordering from the factory.?? They will keep the formula on file.?? You can either specify my name PETE CRAWFORD or their identification EP420GREEN22.
Points of contact: Greg, email greg@conaircraft.com Davina, davina@conaircraft.com
Pete Crawford
