Re: Pitot/static tube fabrication
Ranchaero Wing Shop
Post by Ranchaero Wing Shop »
'My pitot tube was seriously trashed, so after determining that finding a
replacement was futile,  I set about to make a new one. Nothing too
challenging here, except...those (damn) 6 tiny little slots (static
openings) in the rear section of the forwardmost 1/2" tube which is the
static section of the tube. I hoped my machinist would have a good
answer, but not so, yet. He's stumped too. How to cut those 6 tiny slots
1/4" long, about .030 wide, 2 rows of 3 slots spaced evenly around the
circumference of the tube just aft of halfway back. A hacksaw blade just
won't do a pretty job. I imagine maybe they were originally stamped. My
water jet guy says his water jet is too brutal for such fine work.
I suspect there's nothing magic about them, it's just static port. But
they've gotta be pretty and look like the originals. One could probably
drill a few little holes and achieve the same result, but 1st I need to
exhaust all resources for doing an identical reproduction.
Can anyone offer a creative possible solution?
David'
Stuart Burgess
Post by Stuart Burgess »
'Hi David
I had a similar problem so I got new brass tube for the body and new 1/4 inch copper tube for the static and dynamic pipes. I then disassembled my old pitot discarding the pipework and reassembled the hardware like to nose cone and the pitot itself onto the new pipes finally soldering it all back into a new body tube. Worked great.
What is the condition of those bits like the shroud that you are trying to remanufacture.
Cheers
Stuart
On Thu, 25 Jul 2019 at 23:58, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
David
Kind regards
Stuart Burgess
Cell: 0711998012Email: stuart@burgess.org.za '
Ranchaero Wing Shop
' Thanks for your reply, Stuart. Unfortunately, the 1/2" brass tube shroud was also trashed by the mechanic I took over this project from who did a poor job of separating it from the tubes. But that's ok - I enjoy the experience.
Since I posted my last message, my machinist tells me he can make those slots with a tiny (1/32") end mill, and a little filing to square off the ends of the slots with a jewelers file. So he will be doing that part for me, except the filing.
I believe the entire assembly is finally nickel plated. I am studying this process now at Youtube University. Doesn't look too difficult...
David
On 7/26/19 1:16 AM, Stuart Burgess stuart@burgess.org.za [fairchildclub] wrote:
  Hi David
Cheers
Stuart
David
Kind regards
Stuart Burgess
Cell: 0711998012 Email: stuart@burgess.org.za
Stuart Burgess
'Hi David
Glad you have a plan! I started out with the bits that I salvaged and ended
up with a fully functional pitot. Could not find the thin walled brass tube
for the body but fortunately what I found was the right OD but with a
slightly thicker wall.
All that remains is to have it plated. Apologies for the poor second pic.
Only realised when I downloaded the pic that it had focused on the
background but you get the idea.
Stuart
On Fri, 26 Jul 2019 at 17:58, Ranchaero Wing Shop
> experience.
> David
> wrote:
> Hi David
> remanufacture.
> Cheers
> Stuart
>> David
> Kind regards
> *Stuart Burgess*
> *Cell: 0711998012*
> *Email: stuart@burgess.org.za *
Kind regards
*Stuart Burgess*
*Cell: 0711998012*
Ranchaero Wing Shop
' Where I live here in California it's hard to find anyone doing plating anymore. Environmental regs I suspect. From watching Youtube videos, it doesn't seem like there's much to nickel plating. Make a non-conductive tank big enough to submerge the pitot tube, some chemical available on Amazon or you can make your own, some nickel electrode material, a small power supply. There's several Youtube videos demonstrating the process. I haven't tried it yet but I'm gathering up the materials.
Stuart, where can I see your pics? I didn't receive any. Did you send them to me or the list? I must've missed them somehow.
David
On 7/28/19 11:16 PM, Stuart Burgess stuart@burgess.org.za [fairchildclub] wrote:
Hi David
Stuart
david@ranchaerowingshop.com [fairchildclub] fairchildclub@yahoogroups.com
> experience.
> David
> wrote:
> Hi David
> remanufacture.
> Cheers
> Stuart
>> David
> Kind regards
> *Stuart Burgess*
> *Cell: 0711998012*
> *Email: stuart@burgess.org.za stuart@burgess.org.za*
Kind regards
*Stuart Burgess*
*Cell: 0711998012*
Stuart Burgess
'Hi David
I dont often log on to the group but follow the emails so I sent by reply
to the email address |I received from. I have included your email address
here so lets see if this works.
Cheers
Stuart
On Mon, 29 Jul 2019 at 17:09, Ranchaero Wing Shop
> David
> wrote:
> Hi David
> Stuart
> > experience.
> this
> > David
> > wrote:
> > Hi David
> nose
> back
> to
> > remanufacture.
> > Cheers
> > Stuart
> >> David
> > Kind regards
> > *Stuart Burgess*
> > *Cell: 0711998012*
> Kind regards
> *Stuart Burgess*
> *Cell: 0711998012*
Kind regards
*Stuart Burgess*
*Cell: 0711998012*
Post by robert Etter »
' I think that I saw someone mentioned drilling tiny holes all the way through the static line.  I think that mine had two sets of holes, maybe 1/4" apart, front to back and rotated 90 deg. apart.  The end was plugged with a soft rivet turned down to match the tube diameter.  I used the smallest drill bit that I could find.  I didn't know it at the time, mine was home made.
On ?Tuesday?, ?July? ?30?, ?2019? ?12?:?09?:?55? ?AM? ?PDT, Stuart Burgess stuart@burgess.org.za [fairchildclub] wrote:
Hi David
Cheers
Stuart
> David
> wrote:
> Hi David
> Stuart
> > experience.
> this
> > David
> > wrote:
> > Hi David
> nose
> back
> to
> > remanufacture.
> > Cheers
> > Stuart
> >> David
> > Kind regards
> > *Stuart Burgess*
> > *Cell: 0711998012*
> Kind regards
> *Stuart Burgess*
> *Cell: 0711998012*
Kind regards
*Stuart Burgess*
*Cell: 0711998012*
#ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659 -- #ygrps-yiv-325112190yiv6733947659ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp #ygrps-yiv-325112190yiv6733947659hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp #ygrps-yiv-325112190yiv6733947659ads { margin-bottom:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad { padding:0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad p { margin:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mkp .ygrps-yiv-325112190yiv6733947659ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc { font-family:Arial;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc #ygrps-yiv-325112190yiv6733947659hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ygrp-lc .ygrps-yiv-325112190yiv6733947659ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span { font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span:first-child { text-transform:uppercase;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span span { color:#ff7900;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659activity span .ygrps-yiv-325112190yiv6733947659underline { text-decoration:underline;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach div a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach img { border:none;padding-right:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach label { display:block;margin-bottom:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659attach label a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 blockquote { margin:0 0 0 4px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659bold a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 dd.ygrps-yiv-325112190yiv6733947659last p span.ygrps-yiv-325112190yiv6733947659yshortcuts { margin-right:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659attach-table div div a { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659attach-table { width:400px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:active, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:hover, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659file-title a:visited { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:active, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:hover, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div.ygrps-yiv-325112190yiv6733947659photo-title a:visited { text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 div#ygrps-yiv-325112190yiv6733947659ygrp-mlmsg #ygrps-yiv-325112190yiv6733947659ygrp-msg p a span.ygrps-yiv-325112190yiv6733947659yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659green { color:#628c2a;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659MsoNormal { margin:0 0 0 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 o { font-size:0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div { float:left;width:72px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659reco-category { font-size:77%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659reco-desc { font-size:77%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 .ygrps-yiv-325112190yiv6733947659replbq { margin:4px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg select, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 input, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg pre, #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 code { font:115% monospace;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-mlmsg #ygrps-yiv-325112190yiv6733947659logo { padding-bottom:10px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-msg p#ygrps-yiv-325112190yiv6733947659attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-reco #ygrps-yiv-325112190yiv6733947659reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-sponsor #ygrps-yiv-325112190yiv6733947659ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text { font-family:Georgia;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-text tt { font-size:120%;} #ygrps-yiv-325112190 #ygrps-yiv-325112190yiv6733947659 #ygrps-yiv-325112190yiv6733947659ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-325112190 '
Craig
Post by Craig »
'David: If you are still workings on this, might be worth looking at MSC
for a 1" jeweler's saw with the correct blade width. I know that they
come down as thin as .010".
Craig
Fairchild AT-21'
Ranchaero Wing Shop
' Craig, Thanks for your suggestion. I found those 1" dia. jewelers saw blade at MSC.  As you suggest, it could be done with a tiny jewelers saw in a milling machine. Or maybe I could even do it using my drill press. My machinist wants to cut those tiny slots on his CNC milling machine and a .032 end cutter.  I think I'll let my machinist do this one just to get it done. Then I'm going to experiment with a 1" saw and my drill press. Good idea! Thanks!
David
Craig
Fairchild AT-21
Craig
Post by Craig »
David: Good deal. Make sure you take some photos as things are laid out and going back together. Photos and some descriptions as things progress ( good or bad) are worth a lot to?? helping anyone else that needs to make one.
Craig
Fairchild AT-21
On 8/4/19 10:51 AM, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
Craig, Thanks for your suggestion. I found those 1" dia. jewelers saw blade at MSC.?? As you suggest, it could be done with a tiny jewelers saw in a milling machine. Or maybe I could even do it using my drill press. My machinist wants to cut those tiny slots on his CNC milling machine and a .032 end cutter.?? I think I'll let my machinist do this one just to get it done. Then I'm going to experiment with a 1" saw and my drill press. Good idea! Thanks!
David
Craig
Fairchild AT-21
