'Yep, it wouldn’t have to hold more than a quart or so.By the way Steve; is the new battery in the plane or in the box you gave me? Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 12:09 PM
Subject: Re: [fairchildclub] Re: Radial Pre Oiling Like an air pressurized solvent can with a fitting on it? From: fairchildclub@yahoogroups.com on behalf of Ozzie Carrerou ozzie@arearealestate.com [fairchildclub]
Sent: Wednesday, July 10, 2019 10:49 AM
Subject: RE: [fairchildclub] Re: Radial Pre Oiling These are awesome systems. I was thinking more along the lines of tapping into an oil line and use a portable pressurized container and move form one to another. Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 11:30 AM
Subject: Re: [fairchildclub] Re: Radial Pre Oiling http://www.oilamatic.com/Oilamatic Inc. Aircraft Engine Preoiler and Lubrication SystemsThe Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center."www.oilamatic.com From: fairchildclub@yahoogroups.com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Sent: Wednesday, July 10, 2019 10:04 AM
Subject: [fairchildclub] Re: Radial Pre Oiling Oilamatic advertises in Trade-A-Plane.
Eric Goss
865-361-0259'
' #ygrps-yiv-732404378 P {margin-top:0;margin-bottom:0;} The new one is still in the box. I hooked it up to the battery tender about every other month and alternated between the two.....Any progress?
Sent: Wednesday, July 10, 2019 11:53 AM
Subject: RE: [fairchildclub] Re: Radial Pre Oiling Yep, it wouldn’t have to hold more than a quart or so. By the way Steve; is the new battery in the plane or in the box you gave me? Oswald P. Carrerou, SRA President State Certified General Appraiser RZ 271 State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc 1136 First Street South Winter Haven, FL 33880 Phone (863) 294-2384 Fax (863) 297-9781 ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Subject: RE: [fairchildclub] Re: Radial Pre Oiling These are awesome systems. I was thinking more along the lines of tapping into an oil line and use a portable pressurized container and move form one to another. Oswald P. Carrerou, SRA President State Certified General Appraiser RZ 271 State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc 1136 First Street South Winter Haven, FL 33880 Phone (863) 294-2384 Fax (863) 297-9781 ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Subject: Re: [fairchildclub] Re: Radial Pre Oiling http://www.oilamatic.com/ Oilamatic Inc. Aircraft Engine Preoiler and Lubrication Systems The Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center." www.oilamatic.com From: fairchildclub@yahoogroups.com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Eric Goss
865-361-0259 '
Eric Goss
865-361-0259 '
'Just sorting things out right now. I will definitely keep you updated when we start putting things together Take care Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 1:15 PM
Subject: Re: [fairchildclub] Re: Radial Pre Oiling The new one is still in the box. I hooked it up to the battery tender about every other month and alternated between the two.....Any progress? From: fairchildclub@yahoogroups.com on behalf of Ozzie Carrerou ozzie@arearealestate.com [fairchildclub]
Subject: RE: [fairchildclub] Re: Radial Pre Oiling Yep, it wouldn’t have to hold more than a quart or so.By the way Steve; is the new battery in the plane or in the box you gave me? Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups..com
Subject: Re: [fairchildclub] Re: Radial Pre Oiling Like an air pressurized solvent can with a fitting on it? From: fairchildclub@yahoogroups..com on behalf of Ozzie Carrerou ozzie@arearealestate.com [fairchildclub]
Subject: RE: [fairchildclub] Re: Radial Pre Oiling These are awesome systems. I was thinking more along the lines of tapping into an oil line and use a portable pressurized container and move form one to another. Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups..com
Subject: Re: [fairchildclub] Re: Radial Pre Oiling http://www.oilamatic.com/Oilamatic Inc. Aircraft Engine Preoiler and Lubrication SystemsThe Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center."www.oilamatic.com From: fairchildclub@yahoogroups..com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Eric Goss
865-361-0259'
Eric Goss
865-361-0259'
'Can you send me a picture?ozzie@arearealestate.com Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 11:41 AM
I have a pre-oil tank that uses compress air. I put 2 gal of heated oil and pump through the oil pressure port on the engine. I do that 3 times then I will slowly move the crank as I pump hot oil for another 3 times PaulSent from my iPhone
On Jul 10, 2019, at 07:40, Curt Kinchen ptcurt@gmail.com [fairchildclub] wrote:
'I've used a garden sprayer, or any other pressure pot will do, with the hose connected to the oil pressure port. On Wed, Jul 10, 2019, 7:06 AM dave@hadfield.ca [fairchildclub] wrote: One thing you can do is pull the spark plugs, then wind it up on the starter for :30 seconds or so, until you see oil pressure. With no load, it'll turn faster than normal.
' Not yet STC'ed for the Ranger engine?
Eric Goss
865-361-0259 #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731 -- #ygrps-yiv-1986214788yiv9617549731ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp #ygrps-yiv-1986214788yiv9617549731hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp #ygrps-yiv-1986214788yiv9617549731ads { margin-bottom:10px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp .ygrps-yiv-1986214788yiv9617549731ad { padding:0 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp .ygrps-yiv-1986214788yiv9617549731ad p { margin:0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mkp .ygrps-yiv-1986214788yiv9617549731ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ygrp-lc { font-family:Arial;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ygrp-lc #ygrps-yiv-1986214788yiv9617549731hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ygrp-lc .ygrps-yiv-1986214788yiv9617549731ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity span { font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity span span { color:#ff7900;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731activity span .ygrps-yiv-1986214788yiv9617549731underline { text-decoration:underline;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731attach div a { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731attach img { border:none;padding-right:5px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731attach label a { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731bold a { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 dd.ygrps-yiv-1986214788yiv9617549731last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 dd.ygrps-yiv-1986214788yiv9617549731last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 dd.ygrps-yiv-1986214788yiv9617549731last p span.ygrps-yiv-1986214788yiv9617549731yshortcuts { margin-right:0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731attach-table div div a { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731attach-table { width:400px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731file-title a, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731file-title a:active, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731file-title a:hover, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731file-title a:visited { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731photo-title a, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731photo-title a:active, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731photo-title a:hover, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div.ygrps-yiv-1986214788yiv9617549731photo-title a:visited { text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 div#ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg #ygrps-yiv-1986214788yiv9617549731ygrp-msg p a span.ygrps-yiv-1986214788yiv9617549731yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731green { color:#628c2a;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 o { font-size:0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731photos div { float:left;width:72px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731reco-category { font-size:77%;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731reco-desc { font-size:77%;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 .ygrps-yiv-1986214788yiv9617549731replbq { margin:4px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg select, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 input, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg pre, #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 code { font:115% monospace;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-mlmsg #ygrps-yiv-1986214788yiv9617549731logo { padding-bottom:10px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-msg p#ygrps-yiv-1986214788yiv9617549731attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-reco #ygrps-yiv-1986214788yiv9617549731reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-sponsor #ygrps-yiv-1986214788yiv9617549731ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-text { font-family:Georgia;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-text tt { font-size:120%;} #ygrps-yiv-1986214788 #ygrps-yiv-1986214788yiv9617549731 #ygrps-yiv-1986214788yiv9617549731ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1986214788 '
On Wednesday, 10 July 2019, 19:27:11 CEST, Ozzie Carrerou ozzie@arearealestate.com [fairchildclub] wrote:
Eric Goss
