Re: Radial Pre Oiling
ozzie@arearealestate.com
Radial Pre Oiling
Post by ozzie@arearealestate.com »
Anyone have system drawing for pre-oiling an engine that sits for most of the time. What I mean is an attachment you can pump  oil into bearings etc..
dave@hadfield.ca
Post by dave@hadfield.ca »
'One thing you can do is pull the spark plugs, then wind it up on the starter for :30 seconds or so, until you see oil pressure.  With no load, it'll turn faster than normal.'
Post by Curt Kinchen »
'I've used a garden sprayer, or any other pressure pot will do, with the hose connected to the oil pressure port.
Ozzie Carrerou
Post by Ozzie Carrerou »
'Yes, good suggestion.  I’ve seen a system attached the oil gauge line  under pressure to force oil into the system prior to any cranking. Oswald P. Carrerou, SRAPresidentState Certified General  Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You.  A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 9:51 AM
Subject: [fairchildclub] Re: Radial Pre Oiling
Eric Goss
Post by Eric Goss »
'Oilamatic advertises in Trade-A-Plane.
Eric Goss
865-361-0259'
Steve Link
Post by Steve Link »
' #ygrps-yiv-1456282800 P {margin-top:0;margin-bottom:0;} http://www.oilamatic.com/
Oilamatic Inc. Aircraft Engine Preoiler and Lubrication Systems The Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center." www.oilamatic.com
From: fairchildclub@yahoogroups.com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Sent: Wednesday, July 10, 2019 10:04 AM
Eric Goss
865-361-0259
Paul Cousineau
Post by Paul Cousineau »
'I have a pre-oil tank that uses compress air. I put 2 gal of heated oil and pump through the oil pressure port on the engine. I do that 3 times then I will slowly move the crank as I pump hot oil for another 3 times
Paul
Sent from my iPhone
On Jul 10, 2019, at 07:40, Curt Kinchen ptcurt@gmail.com [fairchildclub] wrote:
Ozzie Carrerou
'These are awesome systems.  I was thinking more along the lines of tapping into an oil line and use a portable pressurized container and move form one to another. Oswald P. Carrerou, SRAPresidentState Certified General  Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You.  A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Wednesday, July 10, 2019 11:30 AM
Subject: Re: [fairchildclub] Re: Radial Pre Oiling   http://www.oilamatic.com/Oilamatic Inc. Aircraft Engine Preoiler and Lubrication SystemsThe Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center."www.oilamatic.com  From: fairchildclub@yahoogroups.com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Subject: [fairchildclub] Re: Radial Pre Oiling    Oilamatic advertises in Trade-A-Plane.
Eric Goss
865-361-0259'
Joe Preston
Post by Joe Preston »
I made a preoiler out of an old grill propane container. I pressurize it to a certain amount on the gauge and turn a valve to start the oil flowing into the engine.
You need to find the right spot on the engine to attach it so the oil is flowing the right direction. It works very well. I really only use it for first time starting though. The oilamatic looks like you use it each time you start.
Joe
Sent: Wednesday, July 10, 2019 11:50 AM
Subject: RE: [fairchildclub] Re: Radial Pre Oiling
President
Fax (863) 297-9781
Oilamatic
[url=https://urldefense..proofpoint.com/v2/url?u=http-3A__www.oilamatic.com&d=DwQC-g&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=_gIkjLX7O3YV8lNnfhvKQ1h0bein5Eoz1WhftPxOg74&m=eEn4oevJCzfcexR5z79BO7dB7SxNfTcEbDIwDqqnE3o&s=bgTk71qXHVs8UBZL0w6wALgw86Vxyl7LF1I15zbBasQ&e=]www.oilamatic.com[/url]
Eric Goss
865-361-0259
Steve Link
' #ygrps-yiv-2063625384 P {margin-top:0;margin-bottom:0;} Like an air pressurized solvent can with a fitting on it?
From: fairchildclub@yahoogroups.com on behalf of Ozzie Carrerou ozzie@arearealestate.com [fairchildclub]
Sent: Wednesday, July 10, 2019 10:49 AM
    These are awesome systems.  I was thinking more along the lines of tapping into an oil line and use a portable pressurized container and move form one to another.   Oswald P. Carrerou, SRA President State Certified General  Appraiser RZ 271 State Certified General Contractor CGC #1511393   AREA Real Estate Appraisers, Inc 1136 First Street South Winter Haven, FL 33880 Phone (863) 294-2384 Fax (863) 297-9781 ozzie@arearealestate.com   Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You.  A.R.E.A, INC.   From: fairchildclub@yahoogroups.com
Subject: Re: [fairchildclub] Re: Radial Pre Oiling     http://www.oilamatic.com/ Oilamatic Inc. Aircraft Engine Preoiler and Lubrication Systems The Oilamatic Preoiler will help reduce engine wear, and ultimately extend the life of your aircraft's engine. To learn more about the Oilamatic Aircraft Preoiler and the company, review the content under "Discovery Center." [url=https://urldefense..proofpoint.com/v2/url?u=http-3A__www.oilamatic.com&d=DwQC-g&c=euGZstcaTDllvimEN8b7jXrwqOf-v5A_CdpgnVfiiMM&r=_gIkjLX7O3YV8lNnfhvKQ1h0bein5Eoz1WhftPxOg74&m=eEn4oevJCzfcexR5z79BO7dB7SxNfTcEbDIwDqqnE3o&s=bgTk71qXHVs8UBZL0w6wALgw86Vxyl7LF1I15zbBasQ&e=]www.oilamatic.com[/url]     From: fairchildclub@yahoogroups.com on behalf of Eric Goss ericgoss@comcast.net [fairchildclub]
Eric Goss
865-361-0259 '
