Re: PT-23 Shimmy
PT-23 Shimmy
I know this has been answered many times. After setting the tail wheel down. violent shimmy. We have rebuilt with bushings. Please point me to previous suggestions '
Re: PT-23 Shimmy
' Tighten cables.
Get Outlook for Android
From: fairchildclub@yahoogroups.com on behalf of ozzie@arearealestate.com [fairchildclub]
Sent: Monday, July 8, 2019 9:03:50 AM
Subject: [fairchildclub] PT-23 Shimmy
Re: PT-23 Shimmy
'Thanks I will try that next Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Monday, July 8, 2019 12:11 PM
Subject: Re: [fairchildclub] PT-23 Shimmy Tighten cables.Get Outlook for Android From: fairchildclub@yahoogroups.com on behalf of ozzie@arearealestate.com [fairchildclub]
Re: PT-23 Shimmy
' To tell you the truth, I don't know of a fix. My only guess is that somewhere down the line that you had someone put the fork from a F-24 on your tail wheel strut. I really don't know of a 24 that hasn't had a shimmy problem. One possible cure that I know of, is to not lubricate the bottom of the strut. Keep it dry, which would add friction to the bottom end. That is what my 24's previous owner did. But of your motor leaks a fair amount of oil, that may be hard to do. You also have an oval tire? That won't help the problem. I have a bit of film footage, from 40 years ago, and it was a local Iowa guy landing on grass. His tail wheel was swinging at least 60 deg. from side to side. He had an oval profile tire. I did use a square shoulder tire on my 24, and it worked well. I don't know what kind of a problem that would cause on a Pt. The only guess that I would have is to put friction in the collar at the bottom of the strut. Another thing that I heard from many years ago, was the owner increase the angle of the fork. Just thinking about that gave me a headache. You can do much of anything with the fork casting, but he may have done something with the bottom end of the strut. Bottom line, I think that most will say that is the nature of the beast...…..Just live with it.
Boy.... I am a lot of help. The last PT that I was in didn't have working brakes, the tail wheel strut was complete worn out. The top end moved but the bottom didn't. That PT was completely reworked and is back flying this spring. Within a year after my ride, it made a forced landing on a highway and it was force off the ride by an oncoming driver. the Right main strut bottom end failed and tore up and across the center section. The cause for that was Magneto issues.
Good Luck. I would send a photo of my project, but it would only get scrambled
I know this has been answered many times. After setting the tail wheel down. violent shimmy. We have rebuilt with bushings. Please point me to previous suggestions #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375 -- #ygrps-yiv-291762728yiv0617258375ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp #ygrps-yiv-291762728yiv0617258375hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp #ygrps-yiv-291762728yiv0617258375ads { margin-bottom:10px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp .ygrps-yiv-291762728yiv0617258375ad { padding:0 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp .ygrps-yiv-291762728yiv0617258375ad p { margin:0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mkp .ygrps-yiv-291762728yiv0617258375ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ygrp-lc { font-family:Arial;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ygrp-lc #ygrps-yiv-291762728yiv0617258375hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ygrp-lc .ygrps-yiv-291762728yiv0617258375ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity span { font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity span:first-child { text-transform:uppercase;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity span span { color:#ff7900;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375activity span .ygrps-yiv-291762728yiv0617258375underline { text-decoration:underline;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375attach div a { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375attach img { border:none;padding-right:5px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375attach label { display:block;margin-bottom:5px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375attach label a { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 blockquote { margin:0 0 0 4px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375bold a { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 dd.ygrps-yiv-291762728yiv0617258375last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 dd.ygrps-yiv-291762728yiv0617258375last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 dd.ygrps-yiv-291762728yiv0617258375last p span.ygrps-yiv-291762728yiv0617258375yshortcuts { margin-right:0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375attach-table div div a { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375attach-table { width:400px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375file-title a, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375file-title a:active, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375file-title a:hover, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375file-title a:visited { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375photo-title a, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375photo-title a:active, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375photo-title a:hover, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div.ygrps-yiv-291762728yiv0617258375photo-title a:visited { text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 div#ygrps-yiv-291762728yiv0617258375ygrp-mlmsg #ygrps-yiv-291762728yiv0617258375ygrp-msg p a span.ygrps-yiv-291762728yiv0617258375yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375green { color:#628c2a;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375MsoNormal { margin:0 0 0 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 o { font-size:0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375photos div { float:left;width:72px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375reco-category { font-size:77%;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375reco-desc { font-size:77%;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 .ygrps-yiv-291762728yiv0617258375replbq { margin:4px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg select, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 input, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg pre, #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 code { font:115% monospace;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-mlmsg #ygrps-yiv-291762728yiv0617258375logo { padding-bottom:10px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-msg p#ygrps-yiv-291762728yiv0617258375attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-reco #ygrps-yiv-291762728yiv0617258375reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-sponsor #ygrps-yiv-291762728yiv0617258375ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-text { font-family:Georgia;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-text tt { font-size:120%;} #ygrps-yiv-291762728 #ygrps-yiv-291762728yiv0617258375 #ygrps-yiv-291762728yiv0617258375ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-291762728 '
On ?Monday?, ?July? ?8?, ?2019? ?07?:?04?:?06? ?AM? ?PDT, ozzie@arearealestate.com [fairchildclub] wrote:
Re: PT-23 Shimmy
'Thank you Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Monday, July 8, 2019 12:28 PM
To: ozzie@arearealestate.com [fairchildclub]
Subject: Re: [fairchildclub] PT-23 Shimmy To tell you the truth, I don't know of a fix. My only guess is that somewhere down the line that you had someone put the fork from a F-24 on your tail wheel strut. I really don't know of a 24 that hasn't had a shimmy problem. One possible cure that I know of, is to not lubricate the bottom of the strut. Keep it dry, which would add friction to the bottom end. That is what my 24's previous owner did. But of your motor leaks a fair amount of oil, that may be hard to do. You also have an oval tire? That won't help the problem. I have a bit of film footage, from 40 years ago, and it was a local Iowa guy landing on grass. His tail wheel was swinging at least 60 deg. from side to side. He had an oval profile tire. I did use a square shoulder tire on my 24, and it worked well. I don't know what kind of a problem that would cause on a Pt. The only guess that I would have is to put friction in the collar at the bottom of the strut. Another thing that I heard from many years ago, was the owner increase the angle of the fork. Just thinking about that gave me a headache. You can do much of anything with the fork casting, but he may have done something with the bottom end of the strut. Bottom line, I think that most will say that is the nature of the beast...…..Just live with it. Boy.... I am a lot of help. The last PT that I was in didn't have working brakes, the tail wheel strut was complete worn out. The top end moved but the bottom didn't. That PT was completely reworked and is back flying this spring. Within a year after my ride, it made a forced landing on a highway and it was force off the ride by an oncoming driver. the Right main strut bottom end failed and tore up and across the center section. The cause for that was Magneto issues. Good Luck. I would send a photo of my project, but it would only get scrambled Bob On ?Monday?, ?July? ?8?, ?2019? ?07?:?04?:?06? ?AM? ?PDT, ozzie@arearealestate.com [fairchildclub] wrote:
Re: PT-23 Shimmy
' I have helped tail wheel shimmy in other tail wheel aircraft by tightening steering wires/springs and lowering tire inflation pressure slightly.
David
On 7/8/19 11:14 AM, Ozzie Carrerou ozzie@arearealestate.com [fairchildclub] wrote:
David
Thank you Oswald P. Carrerou, SRA President State Certified General Appraiser RZ 271 State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc 1136 First Street South Winter Haven, FL 33880 Phone (863) 294-2384 Fax (863) 297-9781 ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Re: PT-23 Shimmy
'Definitely check cable tension. Also check for anything bent back there, if the pivot axis is not tipped sufficiently aft at the top, it will shake violently (kind of like a defective shopping cart castor). Check this article. Interesting article on tailwheel shimmy - Backcountry Pilot Interesting article on tailwheel shimmy - Backcountry Pilot This interesting look at what actually causes tailwheel shimmy was written by Gilbert Pierce of Pierce Aero. Tail Wheel Shimmy I noticed when flying my Piper Clipper heavily loaded I experience tail wheel shimmy on my Scott 3200 when landing on a h
Yes, I realize it would take some doing to change the angle of the tail wheel on these airplanes, but you never know what they have been through in previous lives - of which these planes have had many...
Sent from Yahoo Mail on Android
'On Mon, Jul 8, 2019 at 10:04, ozzie@arearealestate.com [fairchildclub] wrote:
I know this has been answered many times. After setting the tail wheel down. violent shimmy. We have rebuilt with bushings. Please point me to previous suggestions #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700 -- #ygrps-yiv-616522777yiv2714993700ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp #ygrps-yiv-616522777yiv2714993700hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp #ygrps-yiv-616522777yiv2714993700ads { margin-bottom:10px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp .ygrps-yiv-616522777yiv2714993700ad { padding:0 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp .ygrps-yiv-616522777yiv2714993700ad p { margin:0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mkp .ygrps-yiv-616522777yiv2714993700ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ygrp-lc { font-family:Arial;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ygrp-lc #ygrps-yiv-616522777yiv2714993700hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ygrp-lc .ygrps-yiv-616522777yiv2714993700ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity span { font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity span:first-child { text-transform:uppercase;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity span span { color:#ff7900;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700activity span .ygrps-yiv-616522777yiv2714993700underline { text-decoration:underline;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700attach div a { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700attach img { border:none;padding-right:5px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700attach label { display:block;margin-bottom:5px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700attach label a { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 blockquote { margin:0 0 0 4px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700bold a { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 dd.ygrps-yiv-616522777yiv2714993700last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 dd.ygrps-yiv-616522777yiv2714993700last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 dd.ygrps-yiv-616522777yiv2714993700last p span.ygrps-yiv-616522777yiv2714993700yshortcuts { margin-right:0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700attach-table div div a { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700attach-table { width:400px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700file-title a, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700file-title a:active, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700file-title a:hover, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700file-title a:visited { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700photo-title a, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700photo-title a:active, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700photo-title a:hover, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div.ygrps-yiv-616522777yiv2714993700photo-title a:visited { text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 div#ygrps-yiv-616522777yiv2714993700ygrp-mlmsg #ygrps-yiv-616522777yiv2714993700ygrp-msg p a span.ygrps-yiv-616522777yiv2714993700yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700green { color:#628c2a;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700MsoNormal { margin:0 0 0 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 o { font-size:0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700photos div { float:left;width:72px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700reco-category { font-size:77%;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700reco-desc { font-size:77%;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 .ygrps-yiv-616522777yiv2714993700replbq { margin:4px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg select, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 input, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg pre, #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 code { font:115% monospace;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-mlmsg #ygrps-yiv-616522777yiv2714993700logo { padding-bottom:10px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-msg p#ygrps-yiv-616522777yiv2714993700attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-reco #ygrps-yiv-616522777yiv2714993700reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-sponsor #ygrps-yiv-616522777yiv2714993700ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-text { font-family:Georgia;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-text tt { font-size:120%;} #ygrps-yiv-616522777 #ygrps-yiv-616522777yiv2714993700 #ygrps-yiv-616522777yiv2714993700ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-616522777
Re: PT-23 Shimmy
'Wow, great article. Thanks Oswald P. Carrerou, SRAPresidentState Certified General Appraiser RZ 271State Certified General Contractor CGC #1511393 AREA Real Estate Appraisers, Inc1136 First Street SouthWinter Haven, FL 33880Phone (863) 294-2384Fax (863) 297-9781ozzie@arearealestate.com Confidentiality Notice: This email message, including any attachments, contains information of A.R.E.A. Real Estate Appraisers that may be confidential or legally priviledged and is intended solely for the use of the individual or entity named on this message. If you are not the intended recipient, nor the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any use, disclosure, or distribution of this email is prohibited. If you have received this email in error, please contact the sender by email, fax, or telephone and destroy all paper and electronic copies of the original message. Thank You. A.R.E.A, INC. From: fairchildclub@yahoogroups.com
Sent: Monday, July 8, 2019 3:32 PM
To: fairchildclub@yahoogroups.com; fairchildclub@yahoogroups.com
Definitely check cable tension. Also check for anything bent back there, if the pivot axis is not tipped sufficiently aft at the top, it will shake violently (kind of like a defective shopping cart castor). Check this article. Interesting article on tailwheel shimmy - Backcountry PilotInteresting article on tailwheel shimmy - Backcountry PilotThis interesting look at what actually causes tailwheel shimmy was written by Gilbert Pierce of Pierce Aero. Tail Wheel Shimmy I noticed when flying my Piper Clipper heavily loaded I experience tail wheel shimmy on my Scott 3200 when landing on a h Yes, I realize it would take some doing to change the angle of the tail wheel on these airplanes, but you never know what they have been through in previous lives - of which these planes have had many...Sent from Yahoo Mail on Android
Re: PT-23 Shimmy
Hi
I run my tyre pressure low as 25 psi, seems to solve it for me. If it does start it’s right at the end of the landing roll.
Cheers
Sent from my iPhone
Sent
Hi
Cheers
Sent from my iPhone
Sent
Re: PT-23 Shimmy
'There are no steering cables on the PT series aircraft. The problem is in the strut; most likely the splines are worn plus the yoke at the base of the strut may also be worn. Jack up the tail and remove the strut for inspection and repair. From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
