'I asked a wiring question a few months ago. Master battery switch and mag battery switch and wired in series. Now with the master batt switch on I have 14 volts on the main buss. When I turn on the mag battery switch on the buss voltage drops a less than a volt. That normal?
Jan
N 81265
Sent from my iPad'
Re: F-24 electrical question
' The only thing that comes to mind is when you have the Master switch on you have no load at that time. When you add the Mag Switch to the BATT position, you engage the Master solenoid to the battery circuit load. If you happened to forget and left something else turned on, that may cause the battery voltage to be even lower. It really wouldn't surprise me that much going from open circuit, and no load, to adding some load to the battery circuit and have the voltage to drop. If you add more load to the battery, you should see an increase in the voltage drop. When you have the motor running and the alternator/generator putting out voltage, the voltage should go back up to what ever the charging circuit is set for.I guess you really don't have anything to worry about. Solenoids are quite thirsty when it come to electricity.To me it is basic electronics. I did my basic electronics in 1962 and have dealt with stuff all the way from useful signals in micro Amps range all the way to 200 thousand Watts of RF power. Boy, that will cook your lunch.Good Luck, in case you need it.
Jan
N 81265
Sent from my iPad
#ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855 -- #ygrps-yiv-1428803219yiv5620547855ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp #ygrps-yiv-1428803219yiv5620547855hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp #ygrps-yiv-1428803219yiv5620547855ads { margin-bottom:10px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp .ygrps-yiv-1428803219yiv5620547855ad { padding:0 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp .ygrps-yiv-1428803219yiv5620547855ad p { margin:0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mkp .ygrps-yiv-1428803219yiv5620547855ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ygrp-lc { font-family:Arial;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ygrp-lc #ygrps-yiv-1428803219yiv5620547855hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ygrp-lc .ygrps-yiv-1428803219yiv5620547855ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity span { font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity span span { color:#ff7900;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855activity span .ygrps-yiv-1428803219yiv5620547855underline { text-decoration:underline;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855attach div a { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855attach img { border:none;padding-right:5px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855attach label a { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855bold a { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 dd.ygrps-yiv-1428803219yiv5620547855last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 dd.ygrps-yiv-1428803219yiv5620547855last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 dd.ygrps-yiv-1428803219yiv5620547855last p span.ygrps-yiv-1428803219yiv5620547855yshortcuts { margin-right:0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855attach-table div div a { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855attach-table { width:400px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855file-title a, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855file-title a:active, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855file-title a:hover, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855file-title a:visited { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855photo-title a, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855photo-title a:active, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855photo-title a:hover, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div.ygrps-yiv-1428803219yiv5620547855photo-title a:visited { text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 div#ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg #ygrps-yiv-1428803219yiv5620547855ygrp-msg p a span.ygrps-yiv-1428803219yiv5620547855yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855green { color:#628c2a;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 o { font-size:0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855photos div { float:left;width:72px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855reco-category { font-size:77%;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855reco-desc { font-size:77%;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 .ygrps-yiv-1428803219yiv5620547855replbq { margin:4px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg select, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 input, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg pre, #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 code { font:115% monospace;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-mlmsg #ygrps-yiv-1428803219yiv5620547855logo { padding-bottom:10px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-msg p#ygrps-yiv-1428803219yiv5620547855attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-reco #ygrps-yiv-1428803219yiv5620547855reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-sponsor #ygrps-yiv-1428803219yiv5620547855ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-text { font-family:Georgia;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-text tt { font-size:120%;} #ygrps-yiv-1428803219 #ygrps-yiv-1428803219yiv5620547855 #ygrps-yiv-1428803219yiv5620547855ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1428803219 '
On ?Wednesday?, ?August? ?8?, ?2018? ?12?:?06?:?11? ?PM? ?PDT, 'Jan P. Hedberg' jhed9253@aol.com [fairchildclub] wrote:
Jan
N 81265
Sent from my iPad
'Just returned-read my message. It should read that the voltage drops to less than a volt. Starter works but electric instruments don’t. Aircraft has a field approved Westec gage and I get no oil pressure indication. Really don’t want to start it if I have no oil pressure indication. I have oil at the pressure pick up but...Something isn’t right.
Sent from my iPad
Jan
N 81265
Sent from my iPad
Sent from my iPad
On Aug 8, 2018, at 8:19 PM, Robert Etter robertetter@ymail.com [fairchildclub] wrote:
Jan
N 81265
Sent from my iPad
' I am not personally familiar with the electronic gauges. My only thought would be to replace the oil pressure source with an air pressure line. Of course, not knowing where and how your oil pressure system in installed, that could be a dumb idea. If it was workable, at least you could check to see if the electronic system is working without running your motor. What would be nice about that, if there is an air leak, you wouldn't be making a big mess.My brain isn't working very well today. I have been smelling smoke from the California forest fires for the last couple of weeks, and it is finally getting to me. Between 6,000 ft elevation and smoke, not good. Visibility has been as low as 3 miles. It is close to being IFR in broad day light.
Sorry, Bob
Sent from my iPad
Jan
N 81265
Sent from my iPad
#ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649 -- #ygrps-yiv-2138243178yiv6412428649ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp #ygrps-yiv-2138243178yiv6412428649hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp #ygrps-yiv-2138243178yiv6412428649ads { margin-bottom:10px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp .ygrps-yiv-2138243178yiv6412428649ad { padding:0 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp .ygrps-yiv-2138243178yiv6412428649ad p { margin:0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mkp .ygrps-yiv-2138243178yiv6412428649ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ygrp-lc { font-family:Arial;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ygrp-lc #ygrps-yiv-2138243178yiv6412428649hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ygrp-lc .ygrps-yiv-2138243178yiv6412428649ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity span { font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity span span { color:#ff7900;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649activity span .ygrps-yiv-2138243178yiv6412428649underline { text-decoration:underline;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649attach div a { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649attach img { border:none;padding-right:5px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649attach label a { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649bold a { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 dd.ygrps-yiv-2138243178yiv6412428649last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 dd.ygrps-yiv-2138243178yiv6412428649last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 dd.ygrps-yiv-2138243178yiv6412428649last p span.ygrps-yiv-2138243178yiv6412428649yshortcuts { margin-right:0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649attach-table div div a { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649attach-table { width:400px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649file-title a, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649file-title a:active, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649file-title a:hover, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649file-title a:visited { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649photo-title a, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649photo-title a:active, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649photo-title a:hover, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div.ygrps-yiv-2138243178yiv6412428649photo-title a:visited { text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 div#ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg #ygrps-yiv-2138243178yiv6412428649ygrp-msg p a span.ygrps-yiv-2138243178yiv6412428649yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649green { color:#628c2a;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 o { font-size:0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649photos div { float:left;width:72px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649reco-category { font-size:77%;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649reco-desc { font-size:77%;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 .ygrps-yiv-2138243178yiv6412428649replbq { margin:4px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg select, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 input, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg pre, #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 code { font:115% monospace;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-mlmsg #ygrps-yiv-2138243178yiv6412428649logo { padding-bottom:10px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-msg p#ygrps-yiv-2138243178yiv6412428649attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-reco #ygrps-yiv-2138243178yiv6412428649reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-sponsor #ygrps-yiv-2138243178yiv6412428649ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-text { font-family:Georgia;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-text tt { font-size:120%;} #ygrps-yiv-2138243178 #ygrps-yiv-2138243178yiv6412428649 #ygrps-yiv-2138243178yiv6412428649ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2138243178 '
Sorry, Bob
On ?Thursday?, ?August? ?9?, ?2018? ?01?:?41?:?56? ?PM? ?PDT, 'Jan P. Hedberg' jhed9253@aol.com [fairchildclub] wrote:
Sent from my iPad
Jan
N 81265
Sent from my iPad
