'Folks,
Just about to attach the tail feathers but not sure if the tailplaner (horizontal stab) attachment bolts should go from outside to inside of the fuselage or visa-versa - all manuals that discuss this make no mention of it. What is the consensus?
Many thanks
Re: F24 Stabiliser Attachment bolts
'Nuts to the pilot is general old school rule. JST From: fairchildclub@yahoogroups.com
Sent: Wednesday, May 2, 2018 10:05 AM
Subject: [fairchildclub] F24 Stabiliser Attachment bolts
Folks,
Many thanks
Folks,
Many thanks
'Thanks Jamie,
I have not mounted it yet but was concerned about the ease of fitting the split pins - probably another 'Mirror job' I suspect.
Frank'
Frank'
My take is the pilot is out side on preflight looking to see that the nut has not backed off.
Elton
Sent: Friday, May 04, 2018 12:59 AM
Subject: RE: [fairchildclub] F24 Stabiliser Attachment bolts
Thanks Jamie,
Frank
Elton
Thanks Jamie,
Frank
' Just like every rule, there are exceptions. I tried what I thought, then learned that I was wrong, again. My hardware is in plain sight. I did hide the end of the key in between two of the castles. I got tired of cutting myself when I washed the tail of the old bird.
My take is the pilot is out side on preflight looking to see that the nut has not backed off. Elton From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Thanks Jamie,
Frank #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202 -- #ygrps-yiv-1233584553yiv4362228202ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp #ygrps-yiv-1233584553yiv4362228202hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp #ygrps-yiv-1233584553yiv4362228202ads { margin-bottom:10px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp .ygrps-yiv-1233584553yiv4362228202ad { padding:0 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp .ygrps-yiv-1233584553yiv4362228202ad p { margin:0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mkp .ygrps-yiv-1233584553yiv4362228202ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ygrp-lc { font-family:Arial;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ygrp-lc #ygrps-yiv-1233584553yiv4362228202hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ygrp-lc .ygrps-yiv-1233584553yiv4362228202ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity span { font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity span span { color:#ff7900;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202activity span .ygrps-yiv-1233584553yiv4362228202underline { text-decoration:underline;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202attach div a { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202attach img { border:none;padding-right:5px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202attach label a { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202bold a { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 dd.ygrps-yiv-1233584553yiv4362228202last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 dd.ygrps-yiv-1233584553yiv4362228202last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 dd.ygrps-yiv-1233584553yiv4362228202last p span.ygrps-yiv-1233584553yiv4362228202yshortcuts { margin-right:0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202attach-table div div a { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202attach-table { width:400px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202file-title a, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202file-title a:active, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202file-title a:hover, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202file-title a:visited { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202photo-title a, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202photo-title a:active, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202photo-title a:hover, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div.ygrps-yiv-1233584553yiv4362228202photo-title a:visited { text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 div#ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg #ygrps-yiv-1233584553yiv4362228202ygrp-msg p a span.ygrps-yiv-1233584553yiv4362228202yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202green { color:#628c2a;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 o { font-size:0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202photos div { float:left;width:72px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202reco-category { font-size:77%;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202reco-desc { font-size:77%;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 .ygrps-yiv-1233584553yiv4362228202replbq { margin:4px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg select, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 input, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg pre, #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 code { font:115% monospace;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-mlmsg #ygrps-yiv-1233584553yiv4362228202logo { padding-bottom:10px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-msg p#ygrps-yiv-1233584553yiv4362228202attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-reco #ygrps-yiv-1233584553yiv4362228202reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-sponsor #ygrps-yiv-1233584553yiv4362228202ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-text { font-family:Georgia;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-text tt { font-size:120%;} #ygrps-yiv-1233584553 #ygrps-yiv-1233584553yiv4362228202 #ygrps-yiv-1233584553yiv4362228202ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1233584553 '
On ?Friday?, ?May? ?4?, ?2018? ?08?:?07?:?01? ?AM? ?PDT, Elton Hanneman elton@hanneman.us [fairchildclub] wrote:
Thanks Jamie,
'"Nuts to the pilot" meaning those bolt need the nuts on the inside. From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, May 02, 2018 11:05 AM
Folks,
Many thanks
Folks,
Many thanks
'Yes, just a general rule. JST From: fairchildclub@yahoogroups.com
Sent: Sunday, May 27, 2018 2:28 PM
Subject: RE: [fairchildclub] F24 Stabiliser Attachment bolts "Nuts to the pilot" meaning those bolt need the nuts on the inside. From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Folks,
Many thanks
Folks,
Many thanks
