I sent my propeller to Sensenich for balancing and refinishing. When reinstalling, are there any suggestions/techniques to consider? I marked the prop, prop hub, prop flange, and spline so that the prop will be replaced in the same position before removal. When I removed the prop/hub there seemed to be no lubricant on the spline. Is this normal? I understand that the prop nut should be tightened to 150 man lbs on a 3 ft bar or 450ftlbs. Is there anything I'm missing? Thanks in advance.
Michael Drebo
832 691-0911
Magnolia, TX
Re: Propeller Reinstallation
'Michael,
Follow Sensenich install procedures in detail. Do not over torque. You do not want to break moisture barrier.
You can lube the crankshaft with good qty grease.
Maker sure the cones are in good shape. Remove all trash and polish.
I normally have the bolt hardware cleaned, inspected and re-cad platted.
Clevis pin or bolt should remain loose on nut. If pin or bolt become tight, then you have lost torque. It is an indicator during preflight and maint ck.
JST
Fairchild Club DVD Editor
IAC 5, Chapter President
http://www.iac5.org
Hm 303-648-0130
Cell 303-304-7937
New Email: JamieTreat397@gmail.com
Visit My AR&R LLC Drop Box for past and current projects: ARR Dropbox Link
Quote of the Month: Just remember, if you crash because of weather, your funeral will be held on a sunny day. - Layton A. Bennett
Sent: Wednesday, March 21, 2018 9:50 AM
Subject: [fairchildclub] Propeller Reinstallation
Michael Drebo
832 691-0911
Magnolia, TX
JST
http://www.iac5.org
Hm 303-648-0130
Cell 303-304-7937
Michael Drebo
832 691-0911
Magnolia, TX
'See the link below from Sensenich with their installation guidelines. Follow those regarding installing the hub on the prop. Yes, there should be grease on the props shaft splines.
http://www.sensenich.com/wp-content/uploads/2018/01/Installation_Instructions_Wood_Aircraft_Installation_1452800693.pdf
ptcurt@gmail.com '
Michael Drebo
832 691-0911
Magnolia, TX
ptcurt@gmail.com '
' I had to chuckle a bit. How do you do 150 lbs. on the end of a 2 foot long bar when you weight 230 lbs? Stand on a pair of scales while you are pulling on the bar and stop pulling when the scales reads 230 minus 150 or 80 lbs. Or go to the Auto Parts store and rent a really big torque wrench. Time for another glass of wine. Parts of my tool kit are really big. I have a torque wrench that is 1" drive and about 4' long. You don't dare to drop it on your foot. Why that big? The price was right.
Michael Drebo
832 691-0911
Magnolia, TX
ptcurt@gmail.com #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829 -- #ygrps-yiv-1263912855yiv7802994829ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp #ygrps-yiv-1263912855yiv7802994829hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp #ygrps-yiv-1263912855yiv7802994829ads { margin-bottom:10px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp .ygrps-yiv-1263912855yiv7802994829ad { padding:0 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp .ygrps-yiv-1263912855yiv7802994829ad p { margin:0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mkp .ygrps-yiv-1263912855yiv7802994829ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ygrp-lc { font-family:Arial;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ygrp-lc #ygrps-yiv-1263912855yiv7802994829hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ygrp-lc .ygrps-yiv-1263912855yiv7802994829ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity span { font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity span span { color:#ff7900;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829activity span .ygrps-yiv-1263912855yiv7802994829underline { text-decoration:underline;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829attach div a { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829attach img { border:none;padding-right:5px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829attach label a { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829bold a { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 dd.ygrps-yiv-1263912855yiv7802994829last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 dd.ygrps-yiv-1263912855yiv7802994829last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 dd.ygrps-yiv-1263912855yiv7802994829last p span.ygrps-yiv-1263912855yiv7802994829yshortcuts { margin-right:0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829attach-table div div a { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829attach-table { width:400px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829file-title a, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829file-title a:active, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829file-title a:hover, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829file-title a:visited { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829photo-title a, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829photo-title a:active, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829photo-title a:hover, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div.ygrps-yiv-1263912855yiv7802994829photo-title a:visited { text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 div#ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg #ygrps-yiv-1263912855yiv7802994829ygrp-msg p a span.ygrps-yiv-1263912855yiv7802994829yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829green { color:#628c2a;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 o { font-size:0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829photos div { float:left;width:72px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829reco-category { font-size:77%;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829reco-desc { font-size:77%;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 .ygrps-yiv-1263912855yiv7802994829replbq { margin:4px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg select, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 input, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg pre, #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 code { font:115% monospace;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-mlmsg #ygrps-yiv-1263912855yiv7802994829logo { padding-bottom:10px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-msg p#ygrps-yiv-1263912855yiv7802994829attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-reco #ygrps-yiv-1263912855yiv7802994829reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-sponsor #ygrps-yiv-1263912855yiv7802994829ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-text { font-family:Georgia;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-text tt { font-size:120%;} #ygrps-yiv-1263912855 #ygrps-yiv-1263912855yiv7802994829 #ygrps-yiv-1263912855yiv7802994829ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1263912855 '
On ?Wednesday?, ?March? ?21?, ?2018? ?09?:?02?:?24? ?AM? ?PDT, Curt Kinchen ptcurt@gmail.com [fairchildclub] wrote:
Michael Drebo
832 691-0911
Magnolia, TX
