Hi All
I have just about got my 1940 -41A back in the air. It had its gear knocked off about 13 years ago from a locked brake followed by ground loop. One of the last things left to do was make new entrance steps. I started out trying to duplicate the original steps. I will admit they look neat but in actual use they are not user friendly.
After climbing on and off airplanes,motorcycles,and horse's the last 70 some years. I found most were easier
then my F24. What I came up was far more practical to make and easier to get in and out of the airplane.I
first cut 2 14" length's of 2" streamline tube and 2 5&1/2" length's. Make 35* bevel on the ends for a right and left set. That make the step at about a 10* slope which helps keep your foot from sliding outboard. I cut teardrop end plates about 1/2"oversize of the tube then centered them when I welded them up. I used 1/8"
material for the end plates so they would be blunt. I am sure some one beat me to this over the years I just hadn't seen another F24 done this way.
Elton
NC28525'
Re: Re-Entry Steps
Buster Colvin
Re: Re-Entry Steps
'Let's see a picture of that.
Sent from my iPhone
Hi All
first cut 2 14" length's of 2" streamline tube and 2 5&1/2" length's. Make 35* bevel on the ends for a right and left set. That make the step at about a 10* slope which helps keep your foot from sliding outboard. I cut teardrop end plates about 1/2"oversize of the tube then centered them when I welded them up.. I used 1/8"
material for the end plates so they would be blunt.. I am sure some one beat me to this over the years I just hadn't seen another F24 done this way.
Elton
NC28525
Sent from my iPhone
On Sep 29, 2017, at 3:00 PM, elton@nairial.net [fairchildclub] wrote:
Hi All
Elton
NC28525
Elton Hanneman
Re: Re-Entry Steps
They are off to prime and paint will take a picture as soon as they are back on the plane and post it to the web site.
Sent: Friday, September 29, 2017 3:34 PM
Subject: Re: [fairchildclub] Re-Entry Steps
Sent from my iPhone
Hi All
Elton
NC28525
Sent from my iPhone
Hi All
Elton
NC28525
Re: Re-Entry Steps
' It sound like your airplane is much like mine. I think mine was worse. I don't know the why details, but it was really torn up. Took off the right main gear, flipped over and broke both wings, bent the top of the cabin, main gear attach point. I ended up with a right pre war civilian wing, left UC-61 wing, and what else I am not sure. I am in the final stages of rebuilding the whole airplane, except the 7 small pieces of OE wood, and used 6 pieces of new OE door pieces. I am in the final stages of the electrical, instrument panel forward. Yet to do is plumbing for the motor, fuel, and the control cables for the motor. You sound like you are doing good. I started June 1973,
They are off to prime and paint will take a picture as soon as they are back on the plane and post it to the web site. From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Subject: Re: [fairchildclub] Re-Entry Steps Let's see a picture of that.
Sent from my iPhone
Hi All
Elton
NC28525 #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577 -- #ygrps-yiv-2000156719yiv2122307577ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp #ygrps-yiv-2000156719yiv2122307577hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp #ygrps-yiv-2000156719yiv2122307577ads { margin-bottom:10px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp .ygrps-yiv-2000156719yiv2122307577ad { padding:0 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp .ygrps-yiv-2000156719yiv2122307577ad p { margin:0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mkp .ygrps-yiv-2000156719yiv2122307577ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ygrp-lc { font-family:Arial;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ygrp-lc #ygrps-yiv-2000156719yiv2122307577hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ygrp-lc .ygrps-yiv-2000156719yiv2122307577ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity span { font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity span span { color:#ff7900;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577activity span .ygrps-yiv-2000156719yiv2122307577underline { text-decoration:underline;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577attach div a { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577attach img { border:none;padding-right:5px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577attach label a { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577bold a { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 dd.ygrps-yiv-2000156719yiv2122307577last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 dd.ygrps-yiv-2000156719yiv2122307577last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 dd.ygrps-yiv-2000156719yiv2122307577last p span.ygrps-yiv-2000156719yiv2122307577yshortcuts { margin-right:0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577attach-table div div a { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577attach-table { width:400px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577file-title a, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577file-title a:active, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577file-title a:hover, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577file-title a:visited { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577photo-title a, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577photo-title a:active, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577photo-title a:hover, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div.ygrps-yiv-2000156719yiv2122307577photo-title a:visited { text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 div#ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg #ygrps-yiv-2000156719yiv2122307577ygrp-msg p a span.ygrps-yiv-2000156719yiv2122307577yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577green { color:#628c2a;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 o { font-size:0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577photos div { float:left;width:72px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577reco-category { font-size:77%;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577reco-desc { font-size:77%;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 .ygrps-yiv-2000156719yiv2122307577replbq { margin:4px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg select, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 input, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg pre, #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 code { font:115% monospace;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-mlmsg #ygrps-yiv-2000156719yiv2122307577logo { padding-bottom:10px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-msg p#ygrps-yiv-2000156719yiv2122307577attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-reco #ygrps-yiv-2000156719yiv2122307577reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-sponsor #ygrps-yiv-2000156719yiv2122307577ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-text { font-family:Georgia;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-text tt { font-size:120%;} #ygrps-yiv-2000156719 #ygrps-yiv-2000156719yiv2122307577 #ygrps-yiv-2000156719yiv2122307577ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2000156719 '
On Friday, September 29, 2017, 4:40:30 PM PDT, Elton Hanneman elton@hanneman.us [fairchildclub] wrote:
Sent from my iPhone
Hi All
Elton
hanneman@frontier.com
Re: Re-Entry Steps
'I just posted pictures of my improved entry steps.on the yahoo site.'
