Re: F24 Fuel valve
dc871f
F24 Fuel valve
Post by dc871f »
Still looking for one.
David'
Craig
Re: F24 Fuel valve
Post by Craig »
David: Are you looking for an F-1 valve?
Craig
David
dc871f
Re: F24 Fuel valve
Post by dc871f »
'Fuel valve, quarter turn on/off. Conical type. I dont know what the F-1 is.
Thanks.'
Buster Colvin
Re: F24 Fuel valve
Post by Buster Colvin »
'Is yours broke or missing?  I have 4 projects but valves may be worse than yours
Sent from my iPhone
Thanks.
dc871f
Re: F24 Fuel valve
Post by dc871f »
'Mine is leaking, tried to fix a few times. I use fuel lube on it until it starts dripping and take it apart, clean and repeat with fuel lube.
Jamie Treat
Re: F24 Fuel valve
Post by Jamie Treat »
'Replace with new Andair valves.  Problem solved.
Sent via the Samsung Galaxy S® 4 mini ™, an AT&T 4G LTE smartphone
-------- Original message --------From: "dc871f@yahoo.com [fairchildclub]" Date:07/11/2017 6:19 PM (GMT-07:00) To: fairchildclub@yahoogroups.com Cc: Subject: Re: [fairchildclub] F24 Fuel valve
Cy Galley
Re: F24 Fuel valve
Post by Cy Galley »
'While you have it part, use tooth paste to lap the cone to the body, clean well, then use fuel lube.  Cy  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Tuesday, July 11, 2017 7:19 PM
Image Virus-free. www.avast.com '
Francis Cox
Re: F24 Fuel valve
Post by Francis Cox »
'Have you tried lapping it in with very fine valve lapping paste/toothpaste? - worth a go.
dc871f
Re: F24 Fuel valve
Post by dc871f »
'Do tell!
Any modifications?'
dc871f
Re: F24 Fuel valve
Post by dc871f »
'Yes. I heard of people having success with that, but no dice.'
