Re: Fairchild Fuselage lower bulkheads 3.5 thru 7.
'Does anyone on the Fairchild Club List have tracings of, or a set of, original wooden bulkheads for the 1937 F24G or H models. There are no drawings available for the 41324 Bulkheads at stations 3-1/2 thru 7 and they are unique to only the F and G models. What lower fuselage bulkheads I do have are in such bad shape I can't even use them for templates.If someone has the info I need I will make tracings, and make them available to the club. I already have tracings of the upper bulkheads and will make them available as well.Please contact me if you can help.ThanksRich Seifert 714-356-6950or 1936f24h@gmail.com'
Hello Richard,
I do not have the drawings that you need. But, if you travel to Colorado, you are welcome to inspect my 1937 F-24G, N-19173 and take any measurements, drawings, etc that you may need.
Kindest regards,
John Duncan
From: fairchildclub@yahoogroups.com on behalf of Richard Seifert 1936f24h@gmail.com [fairchildclub]
Sent: Friday, March 31, 2017 3:21 PM
To: Fairchild Club
Subject: [fairchildclub] Fairchild Fuselage lower bulkheads 3.5 thru 7.
Does anyone on the Fairchild Club List have tracings of, or a set of, original wooden bulkheads for the 1937 F24G or H models. There are no drawings available for the 41324 Bulkheads at stations 3-1/2 thru 7 and they are unique to only the F and G models. What lower fuselage bulkheads I do have are in such bad shape I can't even use them for templates. If someone has the info I need I will make tracings, and make them available to the club. I already have tracings of the upper bulkheads and will make them available as well. Please contact me if you can help. Thanks Rich Seifert 714-356-6950 or 1936f24h@gmail.com
Hello Richard,
Kindest regards,
John Duncan
To: Fairchild Club
