Re: Warner Oil Change
Warner Oil Change
'To those of you who fly behind a Warner -- Is there anything I should know about the oil changing procedure for my Warner 165. Are there oil pumps that lose their prime and have to be attended to somehow, etc. Thanks.'
'Yes most definitely! The procedure for releasing the air trapped is in the Fairchild F-24 manual. And I find that the sooner I refill the oil tank after draining the less trouble I have re-priming. When the procedure is complete I rapidly spin the prop by hand with the front plugs removed until It shows pressure. If it does not prime, remove the oil screen plug and and speed prop until you get good flow. Re-instal screen and spin prop. You should now have pressure. It's a great engine.
Sent from my iPad
To those of you who fly behind a Warner -- Is there anything I should know about the oil changing procedure for my Warner 165. Are there oil pumps that lose their prime and have to be attended to somehow, etc. Thanks. '
Sent from my iPad
' Thank you JP, but I’ll be danged if I can find that procedure in the manuals I have, which are the “Fairchild F-24W46 and F-24R46 Owners Manual”, which I presume is the latest for the 24, and the US AAF/NAVY manual, T.O. No. 1-115CA-1, for the UC-61 and UC-61A, 30 July 43, revised 30 May 44. I have also not found it in my Warner engine manuals, nor in Chalkie Stobbart’s Warner engine advice. I know I have seen something on oil pump priming somewhere – maybe it was in something published on this forum, or from Russell Williams’ site. Anyway, JP, if you can find the wording and relay it to me exactly, or refer me to where you know it is written down, or let me know the manuals that have the description if my manuals are not quite the right ones, I would be most grateful. Cheers! Tony F rom: JP jp.lorie@yahoo.com [fairchildclub] Sent: Sunday, March 12, 2017 7:21 PM To: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] Warner Oil Change
Sent from my iPad
Sent from my iPad
'I will look for it and send it to you. The procedure is simply to partially disconnect the oil intake line at the pump allowing air to escape and oil to flow.
Sent from my iPad
Sent from my iPad
Sent from my iPad
Sent from my iPad
Joe Preston
Send it to all of us. I would love to see it as well.
Joe
Sent from my iPad Mini
Sent from my iPad
most grateful.
Cheers!
Tony
F
Sent from my iPad
Joe
Sent from my iPad
most grateful.
Cheers!
Tony
F
Sent from my iPad
Hugh Loewenhardt
'The Fairchild drawing for the Warner 145 engine installation on the 24-C8C model shows the oil line to the pump inlet connection with a raised section in the middle of the line to be just above the bottom of the oil tank, specifically to prevent draining the oil pump, and lose its prime, when draining the oil tank. Check your applicable Fairchild engine installation drawing as it may show a similar oil line configuration for the Warner 165 engine if you determine your oil pump to be above the bottom of your oil tank such that when you drain the oil tank, you will also drain the oil in the pump.
Hugh Loewenhardt
On Monday, March 13, 2017 10:44 PM, "Joe Preston Joe@Preston-Company.com [fairchildclub]" wrote:
Send it to all of us. I would love to see it as well. Joe
Sent from my iPad
Thank you JP, but I’ll be danged if I can find that procedure in the manuals I have, which are the “Fairchild F-24W46 and F-24R46 Owners Manual”, which I presume is the latest for the 24, and the US AAF/NAVY manual, T.O. No. 1-115CA-1, for the UC-61 and UC-61A, 30 July 43, revised 30 May 44. I have also not found it in my Warner engine manuals, nor in Chalkie Stobbart’s Warner engine advice. I know I have seen something on oil pump priming somewhere – maybe it was in something published on this forum, or from Russell Williams’ site. Anyway, JP, if you can find the wording and relay it to me exactly, or refer me to where you know it is written down, or let me know the manuals that have the description if my manuals are not quite the right ones, I would be most grateful. Cheers! Tony F rom: JP jp.lorie@yahoo.com [fairchildclub] Sent: Sunday, March 12, 2017 7:21 PM To: fairchildclub@yahoogroups.com Subject: Re: [fairchildclub] Warner Oil Change Yes most definitely! The procedure for releasing the air trapped is in the Fairchild F-24 manual. And I find that the sooner I refill the oil tank after draining the less trouble I have re-priming. When the procedure is complete I rapidly spin the prop by hand with the front plugs removed until It shows pressure. If it does not prime, remove the oil screen plug and and speed prop until you get good flow. Re-instal screen and spin prop. You should now have pressure. It's a great engine.
Sent from my iPad
To those of you who fly behind a Warner -- Is there anything I should know about the oil changing procedure for my Warner 165. Are there oil pumps that lose their prime and have to be attended to somehow, etc. Thanks. #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038 -- #ygrps-yiv-1308327969yiv6946688038ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp #ygrps-yiv-1308327969yiv6946688038hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp #ygrps-yiv-1308327969yiv6946688038ads { margin-bottom:10px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp .ygrps-yiv-1308327969yiv6946688038ad { padding:0 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp .ygrps-yiv-1308327969yiv6946688038ad p { margin:0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mkp .ygrps-yiv-1308327969yiv6946688038ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ygrp-lc { font-family:Arial;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ygrp-lc #ygrps-yiv-1308327969yiv6946688038hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ygrp-lc .ygrps-yiv-1308327969yiv6946688038ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity span { font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity span span { color:#ff7900;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038activity span .ygrps-yiv-1308327969yiv6946688038underline { text-decoration:underline;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038attach div a { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038attach img { border:none;padding-right:5px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038attach label a { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038bold a { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 dd.ygrps-yiv-1308327969yiv6946688038last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 dd.ygrps-yiv-1308327969yiv6946688038last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 dd.ygrps-yiv-1308327969yiv6946688038last p span.ygrps-yiv-1308327969yiv6946688038yshortcuts { margin-right:0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038attach-table div div a { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038attach-table { width:400px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038file-title a, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038file-title a:active, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038file-title a:hover, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038file-title a:visited { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038photo-title a, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038photo-title a:active, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038photo-title a:hover, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div.ygrps-yiv-1308327969yiv6946688038photo-title a:visited { text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 div#ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg #ygrps-yiv-1308327969yiv6946688038ygrp-msg p a span.ygrps-yiv-1308327969yiv6946688038yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038green { color:#628c2a;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 o { font-size:0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038photos div { float:left;width:72px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038reco-category { font-size:77%;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038reco-desc { font-size:77%;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 .ygrps-yiv-1308327969yiv6946688038replbq { margin:4px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg select, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 input, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg pre, #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 code { font:115% monospace;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-mlmsg #ygrps-yiv-1308327969yiv6946688038logo { padding-bottom:10px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-msg p#ygrps-yiv-1308327969yiv6946688038attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-reco #ygrps-yiv-1308327969yiv6946688038reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-sponsor #ygrps-yiv-1308327969yiv6946688038ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-text { font-family:Georgia;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-text tt { font-size:120%;} #ygrps-yiv-1308327969 #ygrps-yiv-1308327969yiv6946688038 #ygrps-yiv-1308327969yiv6946688038ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1308327969
Hugh Loewenhardt
I will look for it and send it to you. The procedure is simply to partially disconnect the oil intake line at the pump allowing air to escape and oil to flow.On Mar 13, 2017, at 19:53, JP jp.lorie@yahoo.com [fairchildclub] wrote:
Sent from my iPad
Sent from my iPad
